Leaking water To Whom It may concern: I have a maytag washing machine which is dripping water from the bottom of the tub right above the transmission. It only occurs when I have a large load of laundry. When I have a small load of laundry it does not leak. Should I replace the tub bearing or could it be something else? Your help would be appreciated. Thanks, Dave
Alot of times you may have to replace the inner or out tub which can be hard to install. Laundry Parts Market has the complete tub for cheap and is also alot easier to install with 2 people (it's heavy). http://www.laundrypartsmarket.com/ProductDetails.asp?ProductCode=LP-W10269756
Posted on Sep 05, 2012
  • 864 Answers
Does not sound like a bearing problem. Check to see if water is overflowing the top of the tub during spin cycle (due to spin action) and running down the side of the tub.  Water rising up the side of the tub during spin cycle could also be squirting up through bleach dispenser opening and running down side of tub.
Posted on May 30, 2009
My Maytag Ensignia washer ihas started dripping water into the tub area. It had completed its cycle, but contuies to drip. Right know no evidence that its leaking outside the tub area.
Part 2...
Watch the video... halfway down the page.
https://www.bing.com/search?q=maytag+ensignia+water+valve+replacement&form=EDGEAR&qs=PF&cvid=cc208ffd8bb94ec8937beadc9b940d64&pq=maytag%20ensignia%20water%20valve%20replacement&PC=DCTE
Parts houses... Most all have assistance lines, chat, videos and difficulty assessments (requires model number).
Sears has some pretty good on-line documents... but the get pretty EXPENSIVE on their parts
You are looking at the SAME PARTS EVERYWHERE...
Suppliers:
appliancepartspros.com
repairclinic.com
easyapplianceparts.com
partssellect.com (there are more)... and last...
Sears
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Find Your Appliance Parts
http://partssellect.com/
Jun 17, 2016 | Maytag Washing Machines
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loading washer model # 417.43042200 is leaking Hi, I am finding water on the floor after I wash several loads of laundry in a row. My husband took off the bottom front panel and we found...
Could be from the pump shaft seal. If so you need to fit a new pump/Also check not door boot seal is ripped or overfill from powder drawer too much water pressure...
Jan 31, 2011 | Washing Machines
Water dripping into washing machine tub
Your water inlet valve where the water supply hoses connect is probably leaking because it's not shutting off completely because of sediment in the water line. Replace it or you can try cleaning it.
Oct 26, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Water built up in Maytag Washer Model MAV-17
I would check the water valves or the water lines. If the water valve is leaking, the water could be running out and following down the cabinet then in to the tub, or the water valve water line that leads right in to the tub there for leaving a water build up.
Mar 01, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Water leaking
If the water is leaking at what seems like the beginning of the spin cycle it might be the hose connection to the drain pump or the pump itself. If so, it's a lot easier to fix than the drum seal.
Dec 31, 2007 | Maytag SAV5701A Top Load Washer
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
