Question about Dell Inspiron 6400 Notebook
Flashing Battery Light, Run Faster, Dell updates
I have a Dell 9300 Inspron from 05. It still works great but here are my questions. I'm tech challenged, thanks for the help.
1. The battery light is flashing. I have replaced it once. Does it mean its on its way out again?
2. What is the best way or is there an online program that I can run to clean up my computer and make it run a little faster.
3. Are there DELL updates that I should be downloading to help with over all performance.
  • Dell Master
  • 4,806 Answers
Hi there.
Can you tell me what the battery indicator is supposed to be doing and does it only flash on and off when AC power is plugged in?
The best free system tool for cleaning the system is CCleaner, use this nifty little app for cleaning the temp files, temporary internet files and recycle bin.
Also use the registry cleaner to keep system files running smoothly (make sure you back up to the registry when it asks you)
Download CCleaner from here >>>>>
http://www.filehippo.com/download_ccleaner/
And in answer to your last question, there are no updates from Dell apart from any utilities that they may offer.
Posted on May 30, 2009
  • 2,229 Answers
You've asked a lot.
The battery light could indicate it's on its way out. What does the battery life indicate if you unplug the unit from the wall? How old is the battery that is in it now?
You can clean up your computer by using the hard drive cleanup utility in Windows, (in the system tools), and then you can check your hard drive for errors and defrag it (in the tools tab when you are viewing the properties of the hard drive.) You can run msconfig and disable startup programs you don't need.
And--for upgrades, the cheapest upgrade with the most bang for the buck is to increase your memory.
As for Dell updates, you could check their site for updates in utilities.
If all this boggles your mind, let me know and I'll lead you through the steps to do it.
Battery indicator light flashing
could be charging or indicating a bad battery
Feb 25, 2011 | Dell Inspiron 9300 PC Notebook
My power connector keeps flickering and won't
remove the battery and directly run laptop on main power see it it is working or not if it works that means power connector is proper only problem with battery.
Nov 25, 2009 | Dell Inspiron 9300 Notebook
Computer dose not charge battery (replaced battery and same problem).. Computer works fine when pluged into DC power pack.. Computer is A Dell Inspiron 9300.
check if you are using correct Watt of ac adapter.if yes then download the latest BIOS update for your laptop. if all fails then replace the motherboard.
Oct 14, 2009 | Dell Inspiron 9300 Notebook
Battery light is flashing orange on d510 computer
i have a d800 that does the same thing. battery is no good
Apr 21, 2009 | Dell Latitude D600 Notebook
Dell inspiron 9300 wont power up/good battery and charger
check if your systemboar power is on or not, and also check if the fan is spinning or not. If not try and reset your processor.
Apr 20, 2009 | Dell Inspiron 9300 Notebook
Cumputer comes for about 5 seconds and then turn back off
try this...take out battery for a couple of minutes..rub it with your hands...gets rid of static build up, sounds funny but it worked for me!
Apr 01, 2009 | Dell Inspiron 9300 PC Notebook
Dell Inspiron 9300 only starts up when it's been off a while
Jeff,
I have experienced simular issues with Dell laptops. I was told that my motherboard had a short circuit. My redemy wa to replace the motherboard.
I hope this solution works for you. Please remember to select a rating for this solution.
Feb 10, 2009 | Dell Inspiron 9300 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell d620 will not go into charge mode
This is usually caused by a bad battery. Sounds like both batteries are not working properly. They may still hold some charge, but they are wearing out. After all, they are batteries, and bateries wear out. Keep in mind that some batteries are better than others, even though they may be the same brand, some will hold a charge longer, and some wear out faster. I'm on my second new battery in a year and a half on my Dell, the first held a great charge but wore out after approx 8 months, the one I'm using now still charges fine but only last about an hour and 15 mins.
Jun 21, 2008 | Dell Latitude D620 Notebook
Dell Inspiron 6400 Notebook Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
