Question about Sharp AR-235 Copier
H4-00 Error Code for Sharp AR-168D
We are getting an H4-00 error code.  We know it is either blown a fuser lamp or the thermo fuse is bad.  The tech is now saying replacement of the entire fuse assembly is necessary and now we have to wait on him to order it and then come fix it.  Does anyone know of a quick fix until he can reinstall the assembly?  Is replacement the only way to fix it? We are a law office and this is our only copier and fax machine. We are down without it. Please help!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Your Tech is correct in replacing the Unit.
If the Fuser is not reaching the correct Temp it will give the H4-00 Code
The time and money it takes to repair the unit is greater than replacing.
Oredering all the parts for the unit takes longer then ordering the unit.
The only thing a tech can do is clean the Thermistor, reset with sim 14..
If that works, it might work for a hour, might work for days?
I personally carry this Fuser Unit in my car stock as this happens frequently..
Good luck
Posted on Oct 26, 2008
H4 COD FOR SHARP 5316
Posted on Aug 19, 2011
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
When power is on, H and 4 blink by turns.
your fuser tempature is too low. your lamp may not be coming on. your thermo fuse is bad. your tjermistor is bad. you need a tech to rebuild your fuser
Jan 02, 2010 | Sharp AL-1642CS Copier
IT SHOWS ME THIS ERROR CODE C610 WHEN I SWITCH IT ON.
You have blown your thermal fuse, causing an open circuit.
You have to remove the fuser and remove the thermal fuse. It is very easy to get it, it looks like a round black stump with a shiny bottom with 2 space terminals at each end, the bracket should be white, you cant miss it.
remove the thermistor and throw it hard on the concrete outside, you will not break it, what you are looking for is to make it rattle again, once it rattles again, re-install.. and clear the error code..
To do this you will have to do the following;
Press 'stop/reset' then 'start' then left copy exposure button and hold them all down. This will enter simulation/tech mode.
Enter '163' you do this by pressing the + and - buttons (zoom buttons)
'CLE' should show up (Clear)
then press start.
Reboot the machine and you away again.
Oct 13, 2009 | Kyocera KM-1505 Copier
Error code H4-00 and machine is "locked-up" in scan mode
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
Older Canon Copier PC-6re
Then Error code means that the fuser / fixing Lamp is blown or it could be the thirmal fuse is blown. It could also a bad thirmister, that may have caused the fuse to blow. One thing you can look at, will the fixing unit get warm or hot. Do you know any copier techs, as a friend. It is not a easy job to fix this problem. You have to fix it to clear it.... Good Luck
Mar 14, 2009 | Canon Office Equipment & Supplies
Toshiba 1370 Wrench and C7 error but, 0 & 8 and 89 did not help
Press 0 and 8 down before you turn on the machine, holding these down turn on copier, the display should say "ad" press 89 then start ( display will say 3 ) press 0 then start display goes back to "ad" turn off and on copier if wrench comes back take off red cover over hot section and in the middle there is a thermostat (1 screw) and toner build up under it needs to be removed.
Mar 03, 2009 | Toshiba 1370 Black and White Copier
Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
Replace a lamp on a photocopier
Hello, the C5 code will only show up after the C7 code -- Fuser temp. to low. First put a meter on the Thermal fuse and the Thermistor and see if it is blown. The fuse and thermistor are under the black ( usually) fuser cover which runs the lenght of the fuser. If the fuse and /or thermistor are blown, replace. The lamp will not come on if the fuse or thermistor are blown. If the fuse and thermistor are good then take the end cap off of the fuser ( usually 1 screw) and disconnect the brass (usually) from the lamp. Check the lamp ( continuity), is the lamp okay. If not replace the lamp. If all of these are good then check the Solid state relay unit ( usually in the lower right hand side looking at the back of the machine with cover off). If the relay is good then you have to replace the PWB-A, the main board.
Jan 12, 2009 | Office Equipment & Supplies
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
Blingking code C-6 in my kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Mar 02, 2008 | Kyocera KM-1505 Copier
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Sharp AR-235 Copier Logo
4,992 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
