Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Bissell pro heat 2 puts out too much soap
I just replaced the punp in a bissell pro heat steam cleaner. I did a room no problem. I stopped it. Started another room no soap no water and that little red thing on top barly spins, the hand attachement spits out water for about 5-10 seconds. I took apart again looked for crimps in the hoses seemed fine. I read about priming the pump I did that, worked okay... now i dont think the water is comming out fast enough, it spray out well,when I refill the solution and start it up again the soap is gone in seconds...when I had it apart I sucked a blew the hoses inside, blew off the jet sprays... is there pressure build up, no pressure
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Pump prime lost
The Bissell 1697 is a temperamental machine. Loosing prime is the biggest problem. I have found that the tanks and top cover are not designed well. The connecting plug on the bottom of the tank does not set deep enough into the female receptacle. When the plastic starts to warp and it will, two things happen. First the push valve on the male side (tank) may not open and secondly, you get air leaks.
The pump wants to pump water with high mass and not air. Once the air purges, it will build pressure. You can watch the lines with the top open and identify where the air is coming from. 90% of the time it is the bottom of the tank fitting.
The fix is to put a spacer under the metal plate holding the male (tank) receptacle in place. A rubber gasket or O-Ring that spaces the plate down about 3/32". The plate must have the holes beveled to recieve flat head screws so they dont stick down and hold the tank off. Use silicon seal. Plate should protrude from the bottom of the tank surface slightly when you are through.
Slipping drive belt to the pump is the second biggest problem. Also if you take the top off, every thing has to go back in place exactly or the top will not fit correctly. Hose routing is critical.
Nozzle's will plug in a heart beat so keep the tank water clean. Make sure you turn the mixture valve to water only and purge the system with water prior to quiting.
One further thing, the vac connections to the tank are crappy. I have to use a foam seal glued to the tank top to mate with the two existing gaskets on the body. Here again the plastic warps and things start not fitting properly.
Most of the problems are related to plastic warping as usual on modern cheap ****.
Bob
Retired Mech Eng.
Posted on Mar 14, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell proheat
First is the smart mix valve turning like it should? If it is then replace the soap dispensor. Also is the gasket on the valve at the bottom of the bottle?
Posted on Jun 01, 2008
SOURCE: Bissell 1699 ProHeat Clearview Steam Cleaner won't pick up
I found that mine wouldn't suck up the water because the brushes underneath had tons of dog fur behind them. Don't forget to vacuum before using!
Posted on Oct 23, 2008
localwonder
  • 6784 Answers
SOURCE: Bissell Steam Cleaner Model1694.Where to put soap?
The detergent will have to be poured directly into the water tank by using the measuring cup that is attached to the back side of this unit. I have a manual for you that you can print out as well.
Click here for your manual.
Posted on Mar 10, 2009
Soap mixing with water on bissell pro heat 2
Filter clog problem. Check your User's Guide for filter cleaning.
Jul 04, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
Water is leaking out of the upholstery cleaner
Might the button be stuck a bit? We had this problem and rinsed the brushes out and cleaned the connector area with a damp paper towel. Had to push the button in and out several times to be sure it wasn't sticking. Also, when the hose is docked found it tended to hit the docking station and would spray everywhere! Had to turn around the hose w/ the button so it would stop spraying everywhere. Hope this helps.
Apr 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do I change the belt on my Bissell Pro Heat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
twerw
Apr 16, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Directions for pro heat steam cleaner
If you go to http://www.bissell.com/customer-support/ and type in the specific model number of your Bissell in the space headed by "Find Replacement Parts & Download User Guides", it will provide you with a list of documents for your model. This is presuming that your model is not too old.
Feb 26, 2010 | Bissell Vacuums
Soap will not dispense from Bisell Pro Heat carpet cleaners
This is a design flaw. The pump design has a problem with staying primed. Only going to another brand will you solve this problem. I recommend the Royal 7900 series extractor.
Oct 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell steam cleaner model 9300 not putting out soap
heatman101
,b..,
May 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
183 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
