Sony TB model # KV-27S10 won't go back to original settings
Thanks in advance for your help!
I hooked up a new DVD/VCR player to my TV.
The cable channels were coming in fine before I played a DVD through the combination of the new set up.
Now I can't get the TV back to the normal factory settings no matter what I try.
I have already disconnected the DVD/VCR player and am taking it back to the store for a refund.
But I am left with a TV that is no longer restored to factory settings or normal setup even after I press the set up button and watch it go through the channels trying to restore them.
Please help.
Thanks
  • Anonymous Feb 28, 2008
    i've hooked up my direct tv to the A/V jacks in the back of the TV, how do i get the picture.
    Genius:
  • 1,694 Answers
Hook the cable tv signal directly from the wall to the tv,
then activate auto-memory. The tv should stop going thru the
channels once it finishes memory procedure.
Posted on Oct 23, 2007
Sony KV-27S10 has intermittent tuner issues. moving the cable connection on the back of the set sometimes clears the picture.
This was a common problem with the Tuners of these models. The replacing of the Tuner should fix the Problem. You may be able to order it from Sony.
Here is their Customer Service Number.
1800-222-Sony
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KV-27S10 27" TV
NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
May 09, 2009 | Televison & Video
DVD is wired to the VCR and does not work
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
Dec 24, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Aug 06, 2008 | Sony KV-27S10 27" TV
Sony Trinitron Model KV-27S10
If hte set is a Sony, the standby light should be blinking a code. Report that code here and we should be able to guide you. That code will indicate the problem circuit within the set that has the fault.
Thanks,
Dan
Jun 02, 2008 | Televison & Video
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
SONY Model Number KV-27FS120
Hi. depending of your t.v .. is it old model.. do you have enough a.v. output . if not .. trying to get a audio and video selector .. with a dvd . aux. vcr, a.v. .... for the remote control .. if your t.v and your dvd is listed on the universal remote .. I dont see why not
Dec 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Directv now on video 3, and VCR/DVD player won't work
Playing any source on Chan 3 requires RF coax cable connects hook-up.One is in from source box, other is out to tv.I think you have the coax cables reversed!.......T.
Oct 25, 2007 | Sony KV-36FS16 36" TV
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
