Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
The oven wont heat up above 50
I have a wirlpool Generation 2000+ built in oven
everything works, however it wont heat up above 50!!!
can you please tell me what is wrong?
ideally i dont want to buy a new one if i dont need to
  • Anonymous Mar 28, 2014
    Everything works fine apart oven won't heat to maximum
  • 6,784 Answers
HI, this is not a serious issue here. you will need to test the resistance of the oven temp senors. it seems to be defective. also, check the wiring harness from the oven temp sensor to the control. make sure the wiring harness is in good condition. replace the oven temp sensor if found to be defective.
Posted on May 30, 2009
Where can i obtain manual for built in oven- whirlpool generation 2000?
You can go to apdepot.com and get the manuals.
Oct 29, 2010 | Ovens
How to install oven igniters in Viking VGR48-6GD
Please click on the below link.You will get some ideas to replace it.Everything is explained with the pics.
http://www.explorerforum.com/forums/showthread.php?t=217691
Sep 25, 2008 | Viking 27" Professional Select Built-in...
Built-in Whirlpool model GBS307PRS01 oven won't get hot
First check the thermal fuse to see if it's open circuit and if so replace with http://www.appliancepartscompany.com/product/9223815
This is normally the problem (I have already replaced it twice on my oven).
If this doesn't solve your problem, let me know as there are some other option to try.
Jul 08, 2010 | Whirlpool GBS307PRS Stainless Steel...
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean"...
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Apr 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Wirlpool gold accubake system is not working properly. Broiler works but oven does not heat up properly
If your broiler is working but not the oven, you just need a new bake element. This is a very simply part to replace. Just give us a call or email us with your model number and we;ll send the correct part out to you right away. 972-859-0929. We'll ship this to you and you'll be cooking in no time! We look forward to working with you and hope to hear from you soon. :>)
Oct 03, 2009 | Ovens
Oven wont heat everything else works
If it is a fan assisted oven, and the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Aug 16, 2009 | Maytag 30" Built-In Single Electric Wall...
2 year old elect range/oven by wirlpool will not
check your input voltage your probably losing a leg and only have 120volts instead of 240 volts that would cause a reduced heat symptom
Jul 16, 2009 | Ovens
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
165 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
