Question about D-Link Xtreme N DIR-655 Wireless Router
Work as acsess point
Dir-635 as acsess point dir -655 as n router
  • 4 more comments
  • amgadwadea May 30, 2009
    thanks for your fast reply, my question is, how to link Dir-635 (as Accsess Poin) wireless with Dir-655, because the distance between them around 500m open air.
    thanks,
    regards,
    amgad
    thanks, so much for your assistance, i'll come back soon
    regards,
    amgad
  • amgadwadea Jun 20, 2009
    Sorry for delay in my feed back , because I was abroad, finally I success to convert my Dir-655 to bridge mode with an old firmware, so now I have two devices model Dir-655, how can i configure them as Bridge mode & AP, i need a favor could you please explain to me in simply way because I’m new and not professional in this field
  • amgadwadea Jun 21, 2009
    good morning, firmware 1.03
  • Carl Navarro
    Carl Navarro May 11, 2010
    if m stands for meters, then what do you think? A consumer grade router without detachable antennas, and 1500 feet? Try my favorite website and look to get high-power access points and external antennas. www.tplink.com is a starter place. http://www.radiolabs.com/products/wirele... gets you long range and power. In fact, use a search engine and put in "long range wireless access point" as a search and you can find a lot more equipment.
    On the more reasonable side, a pair of TP-Link 601's and directional antennas should make the hop. About $300 the pair, or take the Radiolabs bridge kit for $75 more.
  • Carl Navarro
    Is there a question in this?
    President:
  • 623 Answers
first let's back up and get the terminology right (otherwise you will not find any information on the internet.)
Your 655 will be the Access point, because it gives access to the wired WAN (ISP, Internet, etc.), or 'outside world".
Your 635 will be called a Bridge, because it bridges the connection from the access point to other wired or wireless clients inside your own network.
If this mode is accessible for you depends on the firmware you have installed. Look at this posting.
Your D-Link 635 is unfortunately not compatible with other firmware, which would be necessary to convert it into a bridge. (See here)
Sorry - but that's the reason why so many people get a Linksys or Buffalo router.
Also - the distance of 500 meters (open air or not) requires an increased transmitting power from the access point (655) and you will have to use different antennas. Third-party firmware also allows you to modify the standard power settings, but you have to make sure that you stay within legal limits of the place where you set this up. If your signal interferes with someone else's, you might get into trouble or even get a fine.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 30, 2009
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
Dir-615 router is detected but cannot get to the internet
Test with network cable, and work backwards to ISP modem to find point of failure.
Nov 19, 2012 | D-Link DIR-615 Wireless Router
I bought a new d-link DIR-600. In configuration settings I had enabled the Access point option and saved the settings now I am unable to access the webportal anymore. Could you tell me what happens when I...
Theres a RESET button near the adopters point. Press it and all the settings will be restored
the new user name will be "user" and there will be no password
Jun 26, 2010 | D-Link DIR-600 Router
I need to get into my roter to set up a wep key
asuming you are conected to your router goto Start>rum Type cmd>ok
in the poped up black screen Type ipconfig >enter. look ate the default gateway numbers in the wireless settings type theas numbers in to a web browser adress bar to acsess your router settings
Jun 04, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
341 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
