Question about Polaroid PhotoMax PDC 3070 Digital Camera
PICTURES I was on vactiosn took pictures and I don't know what happened ,memory were full I took the memory card from the camara and I i went to Walmart to scan my pictures my pictures were gone , I put the card back to the camara tosee my pictures and asked me to format the card, I didn't do anything I didn't format my pictures because said all imagines will delete. My questions is If I still have my pictures there or are erase, Help please
  • 1 more comment
  • TAMAZULA Oct 23, 2007
    I will try your soluction, could you tell me how I format the memory card y the computer where I go. to my computer? and then? please reply thank you
  • TAMAZULA Oct 24, 2007
    Hello again and thank you
    I try to format card on my computer and sing come up all imagines will deleted, I would like to see my pictures that I take on Mexico. I would like to know if there any way !!! please help me I don't want to Deleted my pictures when format my card I hooping that my pictures are there,.   Please Help
    I'M SORRY IT DOESN'T SHOW NOTHING WHEN I OPEN THE COMPUTER WINDOW, AND ALSO I TRIED TO SCAN THE CARD ON MY PRINTER AND SHOW ME  ERROR CARD.AND WHEN I PUT THE CARD ON THE READER THE READER CARD FLASS RED AND GREEN LIKE ERROR, HELP ME PLEASE I DON'T WANT TO LOOSE MY PICTURES, AND THANK YOU SO MUCH FOR YOUR PATIENT
    Novelist:
  • 198 Answers
The problem is simple in nature but may turn out to be more complex than we like to think of it. Normally the pictures should have been saved to the memory card and furthermore they should still be there. However, in this case, if the camera asks you to format the card, it means that the files or the card itself becomed corrupted and the camera can't recognise any of it's files. In this situation, the camera assumes the card is brand new and unformatted (or corrupted/unreadable) and asks for a format. Most cameras use a file system called FAT16 or FAT32. This is a way to manage the space on a memory device (card in this case) and it's standardized with the computer world meaning if you for example take a picture save it on the card and put the card on your computer via a card-reader, the computer will read it normally. If viceversa you place a picture on the card, the camera will read it fine also. However in your case, if the camera says the card is corrupted or it asks you to format the card, there is a great chance the pictures were corrupted and are now unreadable. You should try to place the card on a computer with a card reader. If the computer says the disk is empty, then a data transmission problem between the camera and the card may have resulted in the corruption of those pictures. Format the card on your computer then place it into your camera and make some pictures to see if this was an isolated incident or still the camera takes pictures but doesn't store them correctly.
For those pictures at least, I think there is a veeery slim chance they are still there somewhere. Practically they are corrupted beyound repair, or even worse, they are simply gone. I'm sorry for telling you the bad news, the only thing i can help with now is to try to diagnosticate if this was an isolated incident or there are chances it ca happen again. Like i've told before, first format the card in your computer, then put it in the camera, then make some test pictures and try to see if you can copy them from the card to the pc. Let me know if something happens or if you need more help.
Posted on Oct 23, 2007
  • 1 more comment
  • Motoi  Bogdan
    Motoi Bogdan Oct 23, 2007
    hello again and thank you for the good rating.
    First of all you should have a card reader or a similar device in wich to insert the card from the camera. After you insert the card windows should recognise it as an external hard drive or storage media. it will be shown in "my computer". just right click on it and from the pop-up menu that will come on, select format. A new window will be shown and from there look for FAT 16 in the "file system" option on it. You may now begin the format process by clicking start. After this, the card should be ok, and you may insert it into your camera. If you don't have a card reader, or simply wish to try this another way, format the card using your camera. Simply select "format card" when the camera asks you to do it and after this is done, make some pictures and try to download them to your computer using the camera's data cable. If the pictures are shown properly and they are all ok, your problem was just an unfortunate accident with the card or camera and shoudn't happen again or on regular basis. Feel free to ask further questions.
  • Motoi  Bogdan
    Motoi Bogdan Oct 24, 2007
    does something show up on the card when you open it using your computer? If so, copy anything on the card to the computer just like you would copy a regular folder in windows. Then  check to see if you can see or preview any of the pictures. If possible, or if the pictures have an unusual extension, or they simply don't open, please tell me what name they have or what file extension. I will try to figure out what has become of them and in what status they are.
  • Motoi  Bogdan
    Motoi Bogdan Oct 25, 2007
    I'm sorry but at this point it's pretty obvious that your pictures were corrupted and no longer readable. The only possible way.. and even that has a small chance of succes would be to mount the card as a raw format partition and attempt to extract hexazecimal strings using specialised software/hardware. This can only be done by a specialised service center and even they have a very small chance of succes. By this time, the only thing you may do with that card would be to format it using your computer or replace it if you don't want to risk any situations like this (assuming that the card itself was the problem here). There are many software programs that state they will recover lost files on memory cards but they woun't work in this case, because they can't communicate with the card because windows doesn't report to them that the card is operational or has a valid file system on them. If it were to accidentaly delete a file, or format the card, those programs wound have a chance because they could still read the card. In this case, even windows, as an operating system can't acces the card and therefore any program can't do it also. I'm sorry for being the one to give you the bad news but at this stage I don't think there are many things we can do in order to save the current file system configuration on the card.
The first time i plugged my targus 2.0 memory card reader/writer (model- tgr-msd500) into my computer (windows xp) it worked fine and i was able to upload my pictures to the computer. i took it out and...
Well sometimes when you don't "eject" the memory card properly, the card can have registry errors which makes it corrupt and you can't view the card properly. My suggestion is to put it back in your computer and try to reformat the memory card. This can simply be done by right clicking the card in ""my computer" and choose reform.
May 12, 2011 | Computers & Internet
I took the memory stick out of the camara and plugged it into a card reader for the computer. When I put it back in the camara some of the pictures were corrupted (file error). How do I get the pictures...
one suggestion is if they are still on the card,load them into your computer then open with a picture editing software and save them back to the card as a jpeg image.i have found this to work for me in many cases.hope this helps.
Jan 01, 2011 | Sony Cameras
I need to restart my camara.
I just got a fuji digital camera. I was taking pictures and it said memory full and then the lcd screen went dark gray with a green dot in the middle. I then opened the memory card and installed it. I can still take pictures and see thru the focus lens but not the lcd screen.????? pls. help
Dec 15, 2009 | Canon Cameras
SD Card Issue
Usually when you take pictures using NO SD card you can't take the picture, however in this case the pictures you took are stored in a memory bank temp only to test the picture your actually taking. In the manual what's the size of the built in memory card? Usually it's small amount of memory built in
Sep 07, 2009 | Samsung Digimax S730 Digital Camera
Camara says memory card full, yet when i transfer no pictures
Have you initialised the cards before use? if not you can do that by formatting the cards through Windows. Try it and see if that works. Use NTSC Format.
Jun 23, 2009 | Nikon Coolpix 775 Digital Camera
I can't get to my pictures!
did you buy a memory card along with your camera? I got the camera and they threw in a memory card with it for free. I now know why. My pictures will not always save onto this memory card. i took the memory card out of my old camera and put it in this one, and, the pictures saved. strangely, when i put my new card back in my new camera and took a picture; it saved to it again!
so i believe this could work for you. it sucks. you lose the pictures. but atleast the camera does not have to just be thrown away.
Jan 22, 2009 | Fuji Finepix Z20fd Digital Camera
Camara won t delete photos
Is your memory card locked? It won't let you delete pictures if it is. Check the little switch on the side of the memory card and move it in the opposite direction and then see what happens. Good Luck.
Apr 09, 2008 | Pentax Optio S50 Digital Camera
Olympus SP-320 memory full when 1GB xD picure card in camara
If you download the photos that are on the internal memory to your computer, the next time you take photos it should go to the memory card that is loaded. It worked for me, so I hope that helps
Mar 23, 2008 | Olympus SP-320 Digital Camera
Internal memory problem
they could be on the internal memory try ejecting the card and connect the cameras to the laptop they might pop up then.
Sep 21, 2007 | Fuji FinePix A500 Digital Camera
Missing Pictures
Whatdoes the maual say about the cpacity of the internal memory and what happens when it is full? There is probably a more comprehensive manual on the CD by the way. Come back with the answer and I take it further.
Sep 04, 2007 | Canon PowerShot A60 Digital Camera
Polaroid PhotoMax PDC 3070 Digital Camera Logo
64 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
