Question about Sony Playstation 3 (PS3) Console
It wont run through HDMI
My PS3 English console will not run through the HDMI cable.  We try to install it but it will only load through AV2 setting. (which defeats the object)
I am at my wits end.  I have bought two HDMI cables, one normal and one gold plated and still no joy.  It seems to be trying to install but it just wont after numerous tries !!!!  RAHHHHHH !!!!!!
Please help !!  Could it be my TV ????  It is an LG 32 LX with HDMI.  I change the setting on the tv to HDMI and it still wont work !!!!
Help !!!!!!
  • Lola LuLu Nov 23, 2007
    we have brought our playstation 3 to friends houses and played and then back to our house again and played. this time, our friend got the new samsung tv, so we brought it over, hooked hdmi cables, and watched a fantastic blu ray movie. HOWEVER, when we disconnected the ps3 and brought it back to our house (w our crappy tv) the ps3 does not work. there is no signal. we have tried on two of our tv's (which in the past has worked) and then bought converter cables and it still does not work. PLEASE someone help us, we love our ps3! ps. we think it might have to do with the previous hdmi cable connection, and we do not have hdmi compatible tv's in our home.
  • arsenal12345 Oct 29, 2008
    I have got my ps3 connected to my tele using an HDMI cable and when I go to system settings and change the video output to HDMI and switch to the HDMI channel it just comes up with no input signal. could it be my tele or the actual console? HELP!!!!
Follow the guy aboves solution to reset your Ps3 to 480i. Turn the power to the system off from the switch on the back and then when you flip it back have the power button held down on the front of the system. This only resets the picture doesn't change anything else or erase any games, I had to do it and it works!!
Posted on May 22, 2008
Im having the same problem. It says to check my video out for the hdmi. a few days ago it was working great..
Posted on Aug 18, 2008
The settings on the PS3 are sending the video signal throught the hdmi port. Either go through the XMB via sys settings, display settings, ... Or if you only have a low def tv then hold the power for 5 seconds (when you turn it on i belive) and it resets it. You may have to adjust the audio settings at the same time, because if you pressed yes when the HDMI was first connected, you agreed to send the audio signal via hdmi as well.
Posted on Mar 16, 2008
  • domado Sep 04, 2010
    I had the opposite problem, I bought a used PS3; it worked fine @ the person's house but when we got home it was really hard to load up. I tried this and it worked! Thanks so much for the info, you just saved me $450 (that's what we paid for the tv and the PS3). :-)
Video out to hdmi
Posted on Oct 24, 2007
Ps3 system setting video output to hdmi and it will work
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Blue Ray movies not playing video but can hear the audio
u need to replace the bluyray eye it cost around $130.00 DOLARS
May 27, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read my hdmi cable
first hook up the av cable then do your set up then powerdown then hook up your hdmi if not problem message back
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
How do i change from spanish to english on my ps3
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Please rate, thanks
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont show or load games
If you originally set up the PS3 with A,V cables it won't work on HDMI even if you set it up to and visa versa. There is a work around but you will have to call tech support. Here is a link at Sony's PS3 tech support that may help also.
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
Cant go from a/v cables on my ps3 to hdmi cables! AAAAHHHHHHH
I had the same problem. If you go into the system settings portion of the menu and reset to default settings, then connect your HDMI cable while the system is re-loading, the PS3 should "see" the HDMI cable and ask you if you want to connect your audio and video using that. Hope this helps.
Dec 31, 2007 | Sony Playstation 3 (PS3) Console
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
808 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
