2000 Toyota RAV4 Logo
Posted on Sep 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 Rav4 roof rack rails need to be moved further apart.
I have a 2000 Toyota RAV 4 and the factory roof racks are too close together to make me feel comfortable with my bike up there. How can you adjust them? I have a 2000 Toyota Rav4 with a factory roof rack installed 24 inches apart. I need it to be 30" apart, but don't know how to adjust them. Also, when I bought the vehicle (used) there were no keys which worked with the rack.
George Scott
Level 3:
Master:
  • Master 789 Answers
  • Posted on Sep 02, 2017
George Scott
Master
Level 3:
Master:
Answers
789
Questions
Helped
228517
Points
2507
Ebay for keys--utube video for adjustments
2 Related Answers
Anonymous
  • Posted on Apr 14, 2010
SOURCE: toyota rav4 removable roof rack
also you need 4 rubber pad's looking is attached on the base of the racks, and 4 clips (conected the roof rack w/ the brackets on the roof on you rav) and the key (is the roof rack are locked).
Anonymous
  • 73 Answers
  • Posted on May 02, 2011
SOURCE: 2000 Rav4 roof rack rails
at the end of the roof rack poles are locking devices. They are simple to unlock but are usually a little tricky to find because we dont want them accidentally unlocking when you strap something to them. You have to unlock both ends to move the bars as far apart or as close as you want.
How do I remove a headliner in a 2001 toyota rav4?
roof racks are fitted on the exterior of the body and there is no need to go under the hood lining (holes = leaks) find fitting instructions and you will see how it is done . if no instructions go to a place that sells your roof racks and they will tell you how to do it.
Are you able to advise if a RAV4 will fit under a 25 course (height) garage roof?
25 course? what unit of measurement is that. metric, or Cubits?
measure the top of garage opening
then look up rav 4 height with full tire pressure. unloaded.
with roof rack, or sun roof?
5 ft. 6.3 in.(neat no rack etc)
1684mm
168cm.
1.84 yards
2000 Rav4 roof rack rails need to be moved further apart. How can I do that?
3helpful
I need to remove the luggage racks from my 2007 Hummer h2 SUT
I have the same vehicle and was able to remove mine with the following steps: 1) remove light behind each rear of luggage rack rail using phillips screwdriver (one screw each side). 2) remove molding underneath each light using T20 torx driver (2 screws each side). 3) Loosen cross rails nobs. 4) Side cross rails off of roof.
Can't secure the front cross rail forward for bike rack
dear friend-the roof rack on a sante fe can not be moved.should you attempt that you will have constant rattles on your roof.i can surgest.that you modify your bike rack.
Toyota rav4 removable roof rack
Vibrating, noisy Toyota rav-4 roof rack
  1. Take off the ceiling panel,
  2. Take the panel off, usually have several screws behind the handles, seat belt mount bars, pup the small plastic cover on those bars and you will see the screws.
  3. fter you open th panel, check the losing screw for your roof rack , see if it is with a steel washer, If with the washer, you just need to tighten it, otherwise it is better to add a waser, you don’t have to worry about it again. But you have to check and tight one at a time.
  4. good luck.
Hope this can help.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
