Question about Gateway FPD2275W LCD Monitor
Double image My monitor is showing a little haze double image on everything, is it starting to die?
    Sergeant:
  • 145 Answers
I think yes....the pixel is getting died
if it is still waranty, I sugest you to contact the support center
Posted on May 30, 2009
Haze
Rather hard to properly diagnose this one off such a short description, but...
1/ Bulb OK, not over hours or otherwise damaged?
2/ Is it constant for all images, just a general coloured haze, not a strange "shadow", "ghost" or "fringe" that alters depending on what you display?
3/ Lens nice and clean?
4/ Surface you're projecting it onto also clean and at least nominally white?
5/ Input cables all fine at both ends and work correctly with other output devices (TV and/or computer monitor)?
6/ Haze still in place with different cables and input devices?
7/ Does the projector regularly show the same static image for extended periods?
The VT460s were buggers for suffering from internal LCD and filter glass issues if allowed to overheat, and with image burn-in, especially if fitted with unusual lenses (e.g. extreme short-throw); I've had to do internal cut-and-swap surgery on a few of them before, with donor image elements from projectors that died due to other problems. I can't say the one VT470 has shown any sign of similar, but the two VT480s are worse if anything. So it's entirely possible that we just got the one good VT470 out of the whole production run. As intimated by the above, it could be anything out of a failing bulb, dirty lens (or internal image element) glass, image burn-in, LCD/filter damage from overheating (and mind that being turned on showing a "blank" screen for ages can cause a similar effect, as all of the bulb's 200 watts of light energy is then being completely absorbed by three thumbnail-sized pieces of liquid crystal... the bulb doesn't turn off unless the projector is shut down completely!), problems with internal circuitry, dodgy cables, unsuitable projection surfaces, or problems with the devices feeding images to it. It really is a minefield until it can be narrowed down.
May 11, 2012 | NEC VT470 Multimedia Projector
When i start my monitor its show shadow(double image) for some times and than ok than shadow
plz wash ur moniter with surf excel and then check ur moniter with 1000V it will b ok 4ever
Feb 19, 2010 | IBM ThinkVision L170 17" LCD Monitor
Purple and Green haze on television image
Do you have any speakers near the TV, that aren't shielded... ?That's kinda what it sounds like to me.
Apr 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Mar 14, 2009 | Epson PowerLite® S4 LCD Projector
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
17" Starlogice Screen
It is the main board power failure in the system due component like capacitors shorted.
Feb 01, 2008 | Star Logic 17" LCD Monitor
Showing doubles (red)
Not the red CRT-----problem is called convergence mis-alignment.
Please provide make,model and age for accurate repair details.
Nov 03, 2007 | Televison & Video
Projection Tv Problem
some of these tvs have internal adjustments for everything including alignment which fixes the double image problem. if you remove the cover you will find a lot of little adjustment dials. you may find that they have symbols that show what the adjustment is for. if you want more info. email me at sb1216us@yahoo.com
Sep 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Gateway FPD2275W LCD Monitor Logo
174 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
