Question about Sony Televison & Video
Sony kv 28ls60u
Shortly after switching on screens turns red with horizontal lines and tv goes to standby with led flashing.
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
try checking the soldered joints on the main circut board that attach the larger metal components...I re-soldered aprox 40 connections and now the tv works great!
Posted on Jan 31, 2008
  • 4234 Answers
SOURCE: TV Sony KV-29F1E turn-on failure, red standby LED flashes (starts after 10-20 attempts)
When the set ends up flashing the LED, it should be a repeatable count. Can you please report that count here? Also, since the set eventually works, I'd suspect a bad connection or a part that has changed value over time. The blink code will help to narrow down the offending circuit.
Dan
Posted on May 12, 2008
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Posted on Jul 09, 2008
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Sony kv-34xbr910 wont turn on
I have sony 34 XBR Tube trinitron HD TV. We are not using the TV because it keep giving us 6 blinks and does not turn on
Apr 26, 2008 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony KV-32S20 32" TV and the red standby led flashes constantly. From what Ive read does that mean an an I.C. tv chip # mcz 3001d is bad? I also read that replacing the R-536 with 1 ohm resistor...
you first must verify you have horizontal deflection. do the crt fillaments light up? if they dont you probably have a shorted horiz. output transistor short or a bad solder joint in the drive circuit. i would solder this anyway it is a common issue. it can blow up the power supply if it fails. if they do light up turn up the screen control, the bottom control on the flyback transformer, do you have a flat vertical line? if so you lost vertical deflection. that could also be a bad connection on the ic or it failed.
Dec 28, 2009 | Sony KV-32S20 32" TV
Standby/Timer LED blinking
These unit are famous for the PCB Print to be cracked around the HV Circuit and or the Horizontal Drive Transformer pins needing to be resoldered. It can turn into a very Major repair if the HV Components short. In that case the Power Supply will also short out.
Hope this helps
Skyassoc
Jul 04, 2009 | Sony KV-32S42 32" TV
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
Standby
check secondary voltages and horizontal out put section, and check smps and all the voltages and line out put transformer section...
Sep 29, 2007 | Sony KV-32S42 32" TV
No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Aug 17, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony blinking standby light
This is Sony's way of telling you that there is a short in you set.Probably the horizontal deflection circuit.(Horizontal output transistor shorted??). Also any other short. You need to take it to a techincian and have it checked out. It would be wise to get an estimate! Stargazer
Feb 05, 2007 | Sony KV-32CS70 32" TV
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
