Question about Kenmore 2205x Top Load Washer
Power to the outlet, but apparently no power at the touch pad - it is non responsive with no indicator lights on.
Kenmore Elite Sensor Smart three-speed Automatic Washer; model 22052: Power to the outlet, but apparently no power at the touch pad - it is non responsive with no indicator lights on.
  • 6,784 Answers
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
If all the above checks out OK, replace the touch pad.
Posted on May 30, 2009
Power to Front Control Panel
YOU DEFINITLY HAVE POWER COMING TO THE UNIT?IS THERE A TRANSFORMER?IF YOU HAVE THE CORRECT VOLTAGE AND THE KEYSWITCH (TOUCH PAD)PLUGS INTO THE BOARD YOU REPLACED THE KEYSWITCH IS BAD.HOW DID THE PROBLEM START?
Aug 28, 2007 | Kenmore 16879 Built-in Dishwasher
Kenmore elite 10654606300 won't turn on
Do you have power at the outlet? If you do, your breaker trip as soon as you plug the unit in? If you have power to the unit and your breaker is not tripping, inspect the wires from the power cord to make sure rodents have not chewed the wires. If everything else looks good then you have a bad cntrl board PART NUMBER: 2252116
Mar 25, 2013 | Kenmore Refrigerators
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
In mid cycle machines went dead. Power is ok at
http://www.servicematters.com/maytag_library/docs/16022808.pdf
use the service manual troubleshooting procedure above to isolate your issue and hopefully effect a repair.
May 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite top loader washer won't start. Power is ok at the outlet Unit is 9 years old, model #110-20096993. Unit worked yesterday. It is a sensor smart three speed automatic washer with catalyst
Actually I didn't need a solution. The unit would not start. It was like no power was coming in. The outlet was good and usually if there is a power failute the unit flashes PF. Well I walked by in a couple hours later and and touched the start button and it worked. Got two loads of wash in. It must
have a loose connection or a dirty connector, but I'll wait until it happens again
Thanks
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
"controls locked" red light indicator is lit up...
Hi! mingx2of06
So are any lights on, do you have power at the wall circuit.
InMrFixIt
Aug 08, 2008 | Kenmore Elite HE4 Electric Dryer
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite drying doesn't work sometimes..
Touch pad is failing.Try not to get any moisture around this touch pad.Biggest mistake for all appliances is the touch pad and water dont mix well.
May 21, 2008 | Kenmore Dryers
Kenmore 2205x Top Load Washer Logo
344 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
