Question about Waterway 1 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing # S10115
Installed new 2 speed motor olny low works
When i installed it both work after 5 mins high did not work
    Scholar:
  • 34 Answers
IF the filter is clean, then your problem is electrical. First make sure you are not using an extenesion cord. These pumps do not work well with a cord over 6ft long. Then make sure that the pump is on a dedicated outlet. No Microwaves, computers competing for power. Most likely the pump is not able to draw enough power and is shutting off.
Posted on Jul 03, 2009
Blower motor blows high whenever ignition switch is on
Sounds like your fan switch could be shorted out
Apr 14, 2015 | 2000 Chrysler LHS
Can i install a time temp. type defrost control instead of the demand defrost type in the above unit? also i see no reason for the fan control board (low to High speed) since the fan motor does not call...
Defrost timer might be more reliable here in NY I set them @ 45minutes..The fan speed is out side tempature (ambient) selected ,low speed, running when its cooler out but you still use cooling.HIGH speed being the default speed.High/low during spring and low all winter.If your new motor is only one speed power it direct from the contactor
Jun 07, 2011 | Heating & Cooling
I am installing a Mars 1/3 hp fan motor. It has a black wire,red wire, blue wire, yellow wire and (2) brown wire that go to a capacitor. May Furnace has Black power wire, red wire (speed) and white common....
Hello, Typically your common wire will be white, high speed- black, medium speed- yellow, medium low-blue, red- low. The motor could still run for a short time if it was wired wrong but will either trip a breaker or go off on it;s overload when it's gets hot.
Feb 26, 2011 | Heating & Cooling
Trying to locate where the heater relay that hooks to the blower motor is located
It is mounted on the fire wall in a block of two or three relays depending on what equiptiment is standand in your vehicle.Its toword the left side near the ACand the blower motor units Like i said it depends on what you have some are intergrated into the motor . But if you have splice # S108 the goses to the relay and splits and goes to blower motor resistor unit then its the one on the far right hand side of the block. There all interchangable and work exactly the same. However the blower motor relay directs bat voltage to the blower motor olny at blower high speed setting.The blower motor resistors direct battery voltage at all other speed settings. S o in a nut shell if it works on high the relay is good and its the resistors or a connection issue. Try the connections first thats the most likely problem if you olny have high speed
Jan 21, 2011 | 1999 GMC Yukon
Blower only working on high
It's the resistor. located next to the blower motor, under the dash, on the passenger side.. Easy to replace
Nov 19, 2010 | 2006 Ford Explorer
Washer will barley agitate or spin and make a
Try high speed only (cycles like cottons, heavy duty, etc. This happens when the low speed on the motor is not working. If high speed is working for you, the olny way to make the lower speeds work is to replace the motor.
Your part number is WH20X10019 and it's expensive...
Oct 20, 2009 | GE WBSR3140DW Top Load Washer
Condesor fan stops working
is it one of those Smart motors? it is there save on the electric bill. you actually only need a motor that run fast enough to remove the heat from the coils,one speed you just do not get power saving.
Jul 04, 2009 | Heating & Cooling
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
High speed spa pump shuts off
Pump speed Selector Switch Contact Probably Missing, Checkout
Feb 01, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Waterway 1 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing # S10115 Logo
282 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Mike
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
