Question about Canon ZR80 Mini DV Digital Camcorder
How do I remove lines
I have Grey lines and the audio keep shorting out
  • 2 more comments
  • klee0248 Nov 02, 2007
    I have a similar problem. When I play back the tape, it has grey lines with little colored squares all over the screen. I have absolutely no idea what is causing this, and it does it with all of my tapes which leads me to believe that it isn't a damaged tape issue. Ahh!
  • mbuchallet Nov 03, 2007
    Similar problem with Canon MV830.
  • Anonymous May 12, 2008
    Only on playback mode, do I see perfectly spaced grey lines across the screen, sometimes there are smaller squares within the grey lines, and the sound is intermittent. I have not tried any solutions yet, but I will buy a head cleaner tape and run it through.
  • directorG Sep 29, 2008
    Yuppers, same prob here.  Gray/black horizontal lines perfectly dividing the screen into maybe 6 portions, with portions alternating between line and movie.  While the lines display, the sound quality is horrendously bad.  Occasionally, the tape will "get better," and it takes a moment to do this, digitally "reconstructing" itself to dispose of these lines.
    It now does this to every tape, regardless of what brand.  I'm quite tempted to try out this head cleaner tape, but I hope that would be enough...  Some people have to perform multiple cleanings; can these cleaner tapes be used more than once?
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Posted on Nov 06, 2008
If yu buy a cleaning tapeand run it through the camera, it should work, the heads are just dirty.
Ryan
Posted on Dec 31, 2007
Whats wrong with my led 3d smart tv model code UN46D6420UFZC
Appears to be a Main board issue since both audio and video are involved.
But you might also want to check out the output voltages of your power supply first.
Feb 04, 2016 | Samsung Televison & Video
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
There are grey lines on my camcorder when i playback what i've taped. Will the grey lines show up when i put the video on my computer??
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 23, 2011 | Sony Video Cameras
When I play back the recording it is the image plus grey lines. It is in a striped pattern, recording, grey line, recording, grey line
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Aug 31, 2010 | Canon ZR85 Mini DV Digital Camcorder
I am getting black spots (short black or grey lines) on clothing. The spots appear to be random. Maytag Model DE412
You left something in a pocket that melted in the heat and left those spots and lines. You will need to clean the inside of the drum thoroughly. Without knowing the source of the spot and lines, I can't tell you how to remove them without damaging the clothing.
Jim Hart
Jun 14, 2010 | Dryers
Taskbar turns grey and 2d(98 style) and audio dissapears
apply original windows xp theme and then download ur required theme from another place and then apply it the problem is not solved try reinstalling the driver
Dec 26, 2009 | Computers & Internet
I need to know the color coded wires for a car stereo, pioneer deh1500. whats speaker colors, power colors and constant power
The power color is red,the negative lead is black,the constant power is yellow.Now for the speakers ,the white lead is the + and the white with the black line on it is the - wire ,grey wire + and grey with black line wire - ,green wire + and green wire with black line wire -,purple wire + and purple with black line -.Hope that clear your mind.
Dec 09, 2009 | Pioneer DEH-1500 CD Player
Audio driver for dell vostro A.840. please give me information. thanks
HI
THERE ARE SOME SIMPLE STEPS TO DOWNLOAD THE AUDIO DRIVER FROM THE BELOW SITE .PLEASE FOLLOW THEM....
http://support.euro.dell.com/support/downloads/driverslist
THANK YOU
PLEASE DON'T FORGET TO RATE ME.....
Mar 10, 2009 | AudioControl Overdrive-grey 2 Ch Line...
RCA plugs?
OWNERS MANUAL click here
Usually clarion radios have seperate colors to designate front, rear and sub preamp outputs.
Since youre is grey and black, Assume the grey is front, and black is rear.
If one set is longer than the other, the short is the front, long = rear.
Jan 14, 2009 | Clarion (DB165) CD Player
Canon ZR80 Mini DV Digital Camcorder Logo
555 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
