Question about Mtd 22" Yard Machine Push Mower
Briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
Need point gap and gap specs on coil
  • 15 Answers
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
Were is low oil sensor 13-hp.briggs
check gap on coil the gap on the points and also make sure the magnets are free of rust, the capacitor could be weak also.
Jun 11, 2014 | Briggs & Stratton Ignition Kit 2-8 HP...
Not getting spark in craftsman tractor lawnmower
How old is the engine? Does it have electronic ignition or points? Check the engine stop wire where it attaches to the throttle control on the engine. Make sure it is not grounding out. Has the magneto been removed? That is the Y shaped part behind the flywheel, where the spak plug wire attaches. If the mag has benn removed, it needs to be re-adjusted. The correct gap is .020 of an inch, about the thickness of a matchbook. This gap is measured between the two legs of the mag and the flywheel. I hope this helps, good luck.
May 06, 2014 | Briggs & Stratton Briggs Stratton...
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
What is the gap between he condenser and the piont
The point gap on all Briggs and Stratton engines is .020 inch
Mar 16, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
'Get-Jet' Airplane mover
Hi Freddie ignition- to- flyweel gap means flyweel magnet positioned under the ignition coil armature.Remove the flyweel.Check the flyweel key(if it is sheared off install a new one).Remove the ignition coil.Clean the flyweel magnet and the ignition coil armature.Check the ignition coil wires and terminal to have continuity.Remove the breaker points cover,check the condenser and breaker points(they should not to be burned).The ignition breaker point gap and ignition-to-flyweel gap is 0.020" and the spark plug gap is 0.030". regards savumihai71
Nov 01, 2008 | Briggs & Stratton Electrical Supplies
Mtd 22" Yard Machine Push Mower Logo
797 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
