Question about Uniden PRO538W (40 Channels) 2-Way Radio
Hisses/squeals when transmitting
Cuniden pro538w receives fine, but hisses when transmitting.
  • 50 Answers
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
Posted on May 31, 2009
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
How far will it transmit
good antenna, good radio, good match, barefoot, should transmit about 10 miles providing there isn't to much ground noise.
Dec 27, 2013 | Uniden PRO538W 40-Channels Base CB Radio
Loud squeal/feedback noise when transmitting from a Kenwood TK-3230 to a TK-3400U4p
If you're close enough to hear the receive on one radio while transmitting on the other, it's good old-fashioned feedback. Turn the volume down on the receiving radio.
Jul 11, 2013 | Radio Communications
R/sig meter spikes on my uniden pro538w cb when keying mic
Does the radio put out and receive? And this could be as simple as your SWR switch isn't in the right position. But if your radio seems to work fine then I wouldn't worry to much about the meter it could be out of line I've seen that many times even on new radios.
Jul 15, 2012 | Uniden PRO538W CB Radio, cb radio 40...
My Uniden pro538w is very soft when transmitting, Is there a way to increase mic gain with this radio. I have tried three different mics. all sound like your whispering
Hello Drew
looks like you may have to take this radio in for an alignment. It is to new to to much info on the web yet but sounds like the limiter in it s set to tight and may not be giving you full legal audio.
Ray
May 15, 2010 | Uniden PRO538W 40-Channels Base CB Radio
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Icom IC-2100H Sqealing
The squeal in this model is a famous problem. If you look at the circuit board, you'll see there are a few places where it looks as if someone kinda forgot to put in a ground screw -- even to the point that there are threaded holes in the casting just begging to be filled by the little screws used elsewhere nearby. Take 3 or 4 similar screws, put them in the remaining holes, and make sure all (including the existing ones) are snug. It seems there just weren't enough ground points for all the RF swirling around on the solder side of the board, so there's a bit of RF feedback on this radio. And as long as you've got about 16 amps of clean DC, you're fine; the power leads are correctly fused at 20 amps. BTW, the power amp module in this model is really only spec'd at 144-148; if you're running an odd "MARS or CAP" split, the PA brick can get way unhappy. HTH, -- Barney --
May 07, 2009 | Audio Players & Recorders
CB Squeal When Transmitting
I believe the coiled coax may indeed be the problem. To check, try a temporary rerouting of the cable which eliminates the coils. Dave g.
Dec 20, 2008 | Galaxy Radios DX-44V 40-Channels Base CB...
Uniden PRO538W (40 Channels) 2-Way Radio Logo
241 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
