Question about LG Shine KE970 Cellular Phone
Phone connection problems
Sometimes the phone will not received antenna reception to make or receive phone calls .... after a couple of minutes the reception is back and am able to use the phone... sometimes the reception never comes back... Any ideas why this is happening? Thanks for any help...
  • linkerjt Jun 05, 2009
    I tried the suggestion and the phone still does the same thing... Is there a software update that will fix this problem?
  • linkerjt Jun 10, 2009
    not sure about the warranty... any other tests I can do to see what is the problem... connection issue...to see if it hardware???
  • LG Master
  • 13,433 Answers
Mostly the signal issues are not related to a software problem but most likely a hardware issue, bad antenna or loose contact.
warranty on the phone?
Posted on Jun 06, 2009
  • Ekse Jun 12, 2009
    it would appear to be a hardware issue, software mainly doesn't cause that, atleast I wouldn't have seen a case yet where it wasn't a hardware issue. Loose or poor antenna contact etc.
    President:
  • 1,383 Answers
It is issue with network.
First refix baattry simcard and meory card into cell phone.
Also reset all settings to factory defaults.
Go to menui and settings then reset device.
Also check with other sim card that its network ids good.
Let me know please.
Posted on Jun 04, 2009
  • kishor
    kishor Jun 12, 2009
    u need to change your phone receiver hardware .
My vizio is set on avor antenna I have a HD antenna but TV won't pick up my favorite network stations wtva om nbc or abc
re-orient your antenna , the more the higher the better signal reception you will receive. and check your neighbor tv reception if they are facing the same problem with your tv , the problem isnt with your tv, its the tv network sometimes failed.
Nov 29, 2016 | Vizio Televison & Video
Dish tv support
Hi Vicki,
You may call them at
  • CALL US 1-888-615-3725 for DISH
  • You can also try this steps:
  • MISSING OVER THE AIR CHANNELS The quality of reception and number of channels available depends on the antenna's placement and the customers location. Weather conditions may interfere with channel reception. The Channel Display receiver menu option may not be set correctly.
    1. Check Over-the-Air Antenna ConfigurationCheck that the wiring between your DISH receiver and your over-the-air antenna is configured properly using Setup OTA
    2. Reset ReceiverIf the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
      Please note: It may take up to 5 minutes for the reset process to be completed.
    3. Rescan Over-the-Air Channels to ReceiverAccess "Local Channels" select "Scan Locals" then "Save".
May 08, 2014 | Televison & Video
Bad radio reception
This will be either bad antenna connection in the back of the receiver, bad antenna cable, insufficient or poor antenna type, or possibly a bad earth connection.
Feb 12, 2013 | Kenwood Car Audio & Video
The FM antenna is insufficient. I there a way to improve reception? Another antenna that will fit?
To improve reception, use a 75 Ohm outdoor antenna instead of an indoor antenna. Disconnect the indoor antenna before replacing it with an outdoor antenna.
Dec 14, 2010 | Insignia 200W Stereo Receiver
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Bad reception
Sounds like you have an antenna problem. Find where the antenna plugs into the radio. Unplug it and find a nail or something the same diameter as the center pin wrap about 3-5 turns of a four foot piece of wire around the nail and plug the nail into the antenna input on the radio. If it clears up reception you have a bad or grounded antenna. Follow the antenna wire back to the windshield or fender etc. mounted antenna, sometimes there are other plug in points that get knocked loose.
Jan 12, 2009 | JVC KD-G720 CD Player
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
On the converter box that we hooked up we are geting every channel except 5-1 5-2
Any -1, -2 channles considered as a off-air antenna channels. I assume you have the off-air antenna and good reception on it. So make sure your off air antenna hooked up to your receiver.
If everything is hooked up right and your reception on antenna is good, try to trace the line for your antenna. may find any visual problems such as loosen up, dog chewed the cable etc :D
Last thing if you don't find solution by yourself is call your service provider for service call.
Good luck
Oct 19, 2008 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Apr 22, 2008 | Televison & Video
LG Shine KE970 Cellular Phone Logo
196 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
