Question about Foxconn 661M03-G-6L P4 Socket 478/SiS 661FX/FSB 800/A&V&L/ Motherboard (MOTFO14)
FoxConn 661MO3-G-6EL is suuposed to have 2 1394 Firewire ports installed, 1 in the rear panel and 1 accessible on the board from a front bus connector, but mine seems to be msssing these, whcih does not match the manual or schematics. Can I use a USB or other port connector in some way? Please advise.
    Brigadier General:
  • 10,406 Answers
Return the motherboard to the place where you bought it, and have them explain the differences that you have observed.
Are there any wires running from the FireWire port on the front of your computer's case to any connector on your motherboard?
Posted on May 31, 2009
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Characteristics of n15235 manual motherboard
- Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool: http://tinyurl.com/n8nrz6t.
regards
Sep 16, 2011 | Foxconn 6627MA-RS2H Motherboard
Hi, i want to no, what is 1394 on motherboard and if the usb cable in the front write 1394, i install it like a regular usb cable?????
It is Firewire port/ Interface. The IEEE 1394 interface is a serial bus interface standard for high-speed communications and real-time data transfer, frequently used by personal computers, as well as in digital audio, digital video applications etc. The interface is also known by the brand names of FireWire (Apple), i.LINK (Sony), and Lynx (Texas Instruments). This is not as widely used.It works just like USB but it is meant for connecting Firewire capable devices. If you have any firewire capable device (like video camera)and firewire cable, you can connect the device to your PC and use it for high speed data transfer.
Hope it helps! Good Luck!
CreativeTECH
Apr 18, 2011 | Foxconn 661MX Motherboard (FOX661MXMB)
My board is foxcon 661m03c-mx-6l usb not work
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
don
Feb 18, 2011 | Foxconn 661M03-G-6EL Motherboard
My powermac g4 firewire ports are suddenlt not working.  i think a firewire device might have overloaded them
There is a place under your apple that says about this mac.
Click there.
THen on the bottom of that window it will say more about this mac, click there.
THen go to your contents window and look under hardware. There you will see a file named "firewire". Click on it. If you see information under the area Fire wire Bus than your fire wire bus is working and the problem is your cable from the computer to the Drive. If you do not see any information there or something that says, "Firewire bus not connected or unavailable than that part of your card is messed up on *********** board. If it is not the cable and your machine is under warranty, take it to an apple store and have them replace the board. (Back up your important data first!)
The simple solution with out having to have your machine repaired is to buy a PCI Fire wire card and install that. You should have a separate connection on the front of the mac that is different and check to see if this one is not working either with a new cable.
Dec 17, 2008 | Apple Power Mac G5 Desktop
Does my inspiron b130 laptop support s video output to my tv?
No. INSB130 does not support S-Video. Here's the complete specs of your system:
Processor type Intel® Pentium® M and Celeron® M
External bus frequency (front side bus) 400 MHz or 533 MHz
System chipset Intel 910GML Alviso
Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
Expresscard/54 (54 mm)
1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
Audio Microphone connector, stereo headphones/speakers connector
Mini PCI Type IIIA Mini PCI card slot
Modem RJ-11 port
Network adapter RJ-45 port
USB Three 4-pin USB 2.0-compliant connectors
Video 15-hole connector
Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
Video Type Integrated on system board
Video controller Intel Integrated Graphics Media Accelerator 900
Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
If this is helpful, please rate it.
Dec 05, 2008 | Dell Inspiron B130 Notebook
Location firewire input port
There isn't one on the back panel. You must connect the USB/1394 bracket that's included with the board to an empty slot on the rear of the computer and hook up its connectors INSIDE the computer to the appropriate headers on the motherboard: the purple firewire connector would connect to the purple header (DUH!) on the RIGHT in the pic below, it's a DOUBLE firewire header and it's the only place this bracket will fit. The yellow USB connector would go to any open USB header on the board (guess what color...) Very simple, really.
Optionally if your computer case has a built-in firewire port on the FRONT panel, as most do nowadays, you can connect that to the appropriate header on the board using the already-installed cable that's connected to that front firewire port (connect this one to the purple header on the LEFT, it's just a SINGLE firewire port.)
However, this header's pins will NOT match up properly with almost all case's front-panel firewire connectors. You would most likely have to switch around 2 or 3 of the little wires that go into the connector so that it matches the motherboard's pin-out.
It's clearly labled in the manual for the board, and isn't really all that difficult to switch the wires around, but I would recommend just going with the first option and connect the included bracket to the back since it was designed to go with this board and requires no modification.
Nov 01, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Foxconn 915P7AC-8KS Motherboard
Foxconn 661M03-G-6L P4 Socket 478/SiS 661FX/FSB 800/A&V&L/ Motherboard (MOTFO14) Logo
392 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
