Question about Kenmore 22422 Top Load Washer
Slow cold water flow
I have cleared the cold water hose and reconneted to washer but it did not improve the problem. How do I get to the hoses inside the top of the washer?
  • svqueenbee May 30, 2009
    This is great. And fast. Thanks.
    President:
  • 1,136 Answers
Hi, Did you clean the screen inside the mixer valve or at the valve end of the hose at the wall (not always applies)? If the screen is clear and there is good pressure to the washer, you will need to change the inlet valve.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
We have hot water but no cold water. My washer for a long time spit cold water out real slow then it stoped I checked the hoses and little filter going in to washer it was clean i hear it humming but no...
Start by disconnecting the washer from the cold water hookup, and screw a garden hose to the cold water pipe, running the garden hose to the outside. Then, turn on the faucet to the cold water, and see how it flows out the hose.If it is good, your problem in inside the machine.
You will need to dismantle the washer and inspect the cold water inlet to see if it is plugged up. Sounds like it is. "Sears Parts" online will show you a parts schematic for your machine by model number. They will also show you a parts list. " e-bay" offers new and used washer parts.
Be blessed.
Sep 14, 2011 | GE Washing Machines
Water inlet flow is too slow,it seems lock is not working What to do?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
Have the lock checked at the same time.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 31, 2011 | Samsung Washing Machines
Why does my washer start with a forcful stream and then cut doyn to minimum flow ?
Check for kinked or clogged water supply hoses(s). Be sure to make sure that if there is a screen-like filter in the supply hoses or at the inlet on the wash machine, that it is clear.
Shut the water supply off. Start the washer to fill on warm wash / rinse to relieve the water pressure in the hose. Shut off the washer. Unscrew the hose connection from the washer and direct both hoses into the washer tub (or other container). Turn the water supply on. Both hoses should discharge water evenly and forcefully, then shut the water off. If the flow was uneven, slow or poor - clear obstructions in / or replace the hose(s). Next, inspect the water inlet on the washer. Clear any obstructions, dirt, etc. Reconnect the hoses and try again. If flow is still lacking, there may be obstructions in water lines or valves INSIDE the machine.
I hope this helps - please rate my reply. Thanks.
May 06, 2011 | Craftsman Garden
Cold water supply very very slow
This is a result of a restriction in any one of several places. Start with the washer off / unplugged from the outlet and shut off the water supply that feeds the washer's water supply hoses. The hot a cold water valves (those that are turned off independently of each other) should require the same number of turns to shut off. If not - one is open more than the other and could be a cause for the slow fill. Unscrew the hot AND cold water hose connectors from the washer. Inspect the inside of the connector to ensure there is nothing obstructing the hose itself. Make sure the rubber washer is seated properly, too. Check the entire length of both hoses to be sure there are no kinks or evidence of crushing. Also look for stretched circumference hose that indicate it could breakat any time. Damaged hoses should be replaced promptly to minimize chances of flooding should a hose burst. Hold the ends of the hoses inside the wash machine in such a way that splashing is reduced. Open the water supply and determine if the flow of water is the same or different for the hot and cold water. If the same, the problem is at / in the washer. If unequal flows are detected (with both valves opened the same amount) , the issue is probably with cold water supply or shut off valve. You'll probably have to call a plumber if the difference in flow bothers you that much.
If the flow is the same, it could be a problem with the water inlet or water supply solenoid inside the washer itself. Many washers have a strainer or filter inside the water supply connections. Check yours for foreign objects, debris or build up and clear any found.
Reassemble and and make sure connections are tight (do not use a wrench to tighten) enough to prevent leaking and turn of water supply. Operate the washer and compare cold and hot water flow while filling the tub. If still unequal, you'll have to either call for repair or look further for a restriction in the solenoid valve or deeper inside the machine if it bothers you that much or is painfully slow to fill.
I hope this helps and good luck. Please rate my reply - thanks!
Feb 08, 2011 | GE WBSR3140DW Top Load Washer
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
Cold water flow is extremely slow. have checked
REMOVE THE COLD WATER HOSE FROM THE WASHER, AN LOOK INSIDE THE VALVE, AN CHECK THE SCREEN, FOR BLOCKAGE, SPECIALLY IF YOU HAVE HARD WATER IN YOUR AREA.,
I HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | GE Profile WPRE6100G Top Load Washer
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Very slow cold water flow
soundslike either your cold water supply is not turned on all the way or the inlet valve is clogged w/debris. try removing cold water hose and checkin inside the valve, sometimed youll be able to remove sediment adn debris from valve from screen, if thats not the case youll need to replace the vavle itself
Apr 17, 2008 | Maytag MAV2755A Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
