Question about Dometic Rooftop RV Air Conditioner
No cold air. Unit runs fine.
Can I refill the unit with R22 or something. Is this possible. I just purchased my Camper and wanted to fix this myself if possible. It is A dometic Duotherm model 57915.622 ser # 74517983 Compressor comes on but air is not cool...any way to re-charge with coolant ? barryjoeburns@yahoo.com
    Problem Solver:
  • 10 Answers
Yes if it has service ports but if it lee=aked out you need to fix leak first
Posted on May 31, 2009
  • cinqueneuf Feb 10, 2011
    Is there a solution if there are not service ports
What is going on with our Goodman unit?
If your going to pay that much just have them put in a new unit. It is not that much more and you can get free financing. All the repairman can do is guess and keep putting in new parts till it works. Had a new unit put in and it still didn't work found out it was a bad thermostat. But at lest we don't have the repair bills or high electric bill anymore so it paid for its self in saved money.
Jul 21, 2014 | Goodman Heating & Cooling
How to refill R22 on Reem unit
Some HVAC 'experts' install coil lines without a pressure outlet. (ecspecially older units) In which case, you will have to install one. Usually they are located outside very close to the compressor unit on the inflow copper line. If not present, you can chase the lines back to the cooler head in the furnace/cooling unit plenum. It would be visible at some point in the lines if it was installed in the first place.
Jun 03, 2014 | Whirlwind FH-778 Air Conditioner
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
My rooftop ac on my camper is blowing out air, but its not very cold. i looked on the tag inside under lid on ceiling and it says R22 is that the freon type it needs to be recharged with? and is recharging...
YEP ITS A 22 UNIT, . BY STICKING AC GAUGES ON IT IT WILL TELL YOU THE STATE OF CHARGE.. SHOULD BE DONE BY QUALIFIED PERSON !
JAY THE POOL PUMP MOTOR REPAIR GUY FLORIDA
Jul 21, 2011 | Dometic Rooftop RV Air Conditioner
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
Does not cool room.
Goldstar WG5000 air conditioners use an R22 refrigerant. A charge kit containing the gauges needed to properly fill the unit, and the refrigerant tank/cartridge can be purchased to fill the air conditioner.
Jun 03, 2010 | Goldstar WG5000 Air Conditioner
There are a variety of probable causes of your AC's failure to blow cool air. Unfortunately, it is difficult to diagnose your situation without being there. However, I have a great, handy diagnostic article that specifies the main problems so that you can definitely come to find the cause applicable to your AC's failure. I'm not too familiar with RV AC's and how they may differe a bit from house AC's, but your AC very well may need a recharge of refrigerant/Freon by a technician, but short of that, try this first:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
This should defintely help.
Brad
May 28, 2009 | Dometic Rooftop RV Air Conditioner
2000 roof-top Brisk-Air
I think you have a high pressure cutoff cycling the compressor on and off. Clean the filter inside the unit. Then with a hose clean out the foil condenser filter on top of the camper. Also you may need to buy a coil comb and comb out bent or damaged areas of the condenser coil on the unit that is above the roof of the camper.
Jun 09, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
305 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
