Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
I press the L button on my psp and nothing happens
The L button on my psp just stopped working I can press it but nothing happens I dropped it once and ever since then the L button just dosen't work
  • 3 Answers
Sucks for you!
Posted on May 30, 2009
X triangle square circle button not responding everything else works my brother said he dropped but im sure he did more than that (so i am not really sure what happen ) help please --i cleaned the buttons...
That means the button pad connector might be disconnected to the main board inside that PSP.
Better bring it to your technician to check on it. To access that area your PSP will be open up, the connector is behind the LCD screen.
Hope FixYa helps you out!
Aug 15, 2011 | Sony PlayStation Portable (PSP) Slim...
If i will hold it what will be happened
If you put the switch down to HOLD, all of the buttons will be locked.
In other words, if you press X, O, Start, Select -- nothing at all will happen.
It's really only useful if you use the PSP for playing music and you put it in your pocket or something. It will make sure no buttons are pressed while your music is playing that will skip or stop it by mistake.
Apr 20, 2011 | Sony PSP (Piano Black)
After pressing the audio button on my psp the screen would go black and white from bottom to top then would go back to normal what i tried is to take out the memory card and tr to press the audio...
Hi, I've had the same problems for about a month now. I have a psp fat (psp-1000) with cfw. 5.50. I was playing ZHP unlosing ranger when the same thing happened.
I use the lowest brightness setting to lengthen game play time. I keep using the audio button (The one you hold and turns the sounds mute or back.. right?) for the game then when i reset my game (press home and start the gameover..) the brightness suddenly keeps on changing even making the whole screen black. After 5 minutes? it stops but then when i press the down or square, triangle button the brightness changes sometimes thats the only thing the button does.. i found a temporary fix for this, i put it sleep mode then turn it on again and it stops.. the buttons go back to normal, for a while.
It goes on and on even with other games. It just stops after 10 minutes later or more than starts happening again everytime the brightness or audio button is pressed.
We scanned it for viruses on a computer and it just kept on blinking everytime it responded to the scan. No virus were found but after that when we disconnected it from the computer the brightness problem stopped for a good long time.. we avoided pressing the brightness and audio buttons. but recently its happening again.
and now just got worse. I was playing Socom Fireteam, and when you accidentaly go to the start menu, you have to press "select" to exit and continue the game. But the "select" button wont work!
so i quit the game and startover.. when this happened for the 3rd time. When i pressed "home" button and was asked if i really wanted to exit the game i couldnt move to "yes" and couldnt press the "O" or "X" buttons.
So i turned off my psp and when it went back on, I couldnt press anything anymore. except, the volume buttons and select (the vsh menu appears)
I searched for help from the internet, found "disable your vsh menu" remedy.
It worked! but when i played the game, the "cwcheat" menu keeps on appearing (seplugin that appears when you press select button). It wouldnt stop >.<
So we disabled that too.
Now playing God of War Ghost of Sparta, and one part, the start menu kept on appearing! we'd close it so that we could push one of the levers in the game but then it pauses the game again.. it stopped after a while. then it happened again only slight.
Found a comment on a "select button problem" and it said that it was the:
"parts that were Ribbon style, with it was the start and select button and the volume/sound" he had that parts?
found same problems around the net, some posts from 2009.
found decent posts and solutions here:
http://forums.qj.net/psp-general-help/151111-psp-slim-start-button-stuck.html
the best one says buy a new "flex bar" or "home bar". It goes by many names, but it's the metal bar that has all of the bottom row buttons on it (home -> start) It's usually under $10 USD and obviously the right thing to do.
got another comment that says it worked from him when he bought one himself.
Glad I found others, and that I could share this.. wish it makes things better.
Hope it works out for all of us!
Another thing, Merry Christmas!
Dec 02, 2010 | Video Game Consoles & Games
Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
Hello there
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
Oct 10, 2010 | Sony PSP (Piano Black)
On my psp, everything seems fine except that when I put in a UMD disk to play a game, nothing happens! It's not the disk as this works on another psp. The problem started after I downloaded the latest...
turn on ur psp press the select button and then select reset device it will bring the default setting of your PSP
now chek if still UMD doesnot open then ur new firm ware is corrupt and try reinstaling the firmware from the sony website www.us.playstation.com/PSP/Downloads/systemupdate
update after u reset the device once
Jul 03, 2009 | Sony PlayStation Portable (PSP) Console
My psp's arrow keys dont work
try to tighten ur psp screws a little bit tighter and if it dont work by a replacement kit for it
Jul 02, 2009 | Sony PlayStation Portable (PSP) Console
My psp can connect to my computer..
This is the way I did mine and it worked. Put the PSP into USB mode. Press the HOME button located on the bottom left of your PSP and then scroll left to the SETTINGS column. Scroll down to USB CONNECTION and press X. The Memory Stick inside your PSP will now mount on toyour computer. Hope this helps.
Feb 08, 2009 | Sony PlayStation Portable (PSP) Console
HELLLLPPPPP
First Remove the UMD from PSP if any
1. Switch ON the PSP 2. Press and Hold the Left arrow button until the Sound of "click" Stops. 3. Press and Hold the Up arrow button until the Sound of "click" stops. 4. Press the Down arrow button 4 times (so u will be in System Settings) 5. Press the Enter Button i.e X 6. Press the down arrow button 9 times so u will in "Restore Default Settings" 7. Press Enter button i.e X once 8. Press the Left arrow button once and then press X button once 9. Press the Left arrow button once and the press X button again 10. Press the X button
See whether u r PSP restart and solves the problem
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
I have a sony 2001 PSP, and I've had it for less than a month and just recently I tried to use it, when i attempt to turn it on I press the power button and the green light (which shows that the PSP is on)...
For how long have you NOT been using your PSP? and did anything happen before you even tried using it AGAIN? Do you have others in your area who has a PSP? if nothing happened to your psp before you tried using it again e.g.accidentally fell or something like that, then just try to use a different WORKING psp battery...if it didn't work, then prolly your PSP went brick and the only solution for that is a pandora kit...
Jul 22, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
