Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Lint balls remain in and on clothes after washing cycle is done
Amana washer. Type 107-02. Lint doesn't seem to be draining away. Clothes always have globs of lint on them when removed from the washer. I can't find a lint trap to clean this out. Where might I find one on this washer? thanks for your help
Clothes have lint on them when the washing cycle is finished is there a lint area i need to clean
The newer Whirlpool top-loaders have lint screens on the inner tub and not accessible. These are supposed to self-clean during the drain cycle. I've heard that liquid fabric softener and detergent build-up may clog the screens when lint sticks to the gooey screens. Try something that will cut the goo like vinegar or ammonia in a small load level without clothes. Without clothes in the washer, that is.
Older Whirlpool washers have lint filters located above the tub, on the lid opening.
Good luck from Detroit, MI.
Jul 18, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Dark clothes have lint left on them. what could help this problem?
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint:
1. Turn clothes, particularly black clothes, inside out.
2. Use a concentrated soap with little or no filler.
3. Use less soap than normal.
4. Fully dissolve soap before adding clothes.
5. Run rinse cycle again after completing full wash cycle.
Jun 22, 2011 | Admiral AW22 Top Load Washer
Does this machine have a lint filter? I am getting bits of yuk on my washing after the wash is finished
No lint filter. The tumbling wash action generates very little lint, which washes down the drain.
To get rid of the "yuk":
Open the access panel on the lower left corner on front of the washer.
Use small hose to drain the remaining water from machine.
Remove the pump filter next to the hose, clean it out, and replace it.
Run the washer with a commercial washer cleaner such as Affresh, washer magic, or whirlaway hot tub cleaner, no clothes, hottest longest cycle possible. Use the tub clean cycle if your model has it.
Resume washing, using one tablespoon of HE detergent per cycle. Use only 1 teaspoon of fabric softener if you use that. These machines use much less water than the old top loader ones, and thus you must use much less detergent.
Feb 24, 2011 | LG Washing Machines
All my shirts are ending up with fuzz balls . Is there a lint filter?? i can't seem to find it .
There is no lint filter. Make sure you have enough water to float the clothes. Try washing your shirts with the permanent press or gentle cycle.
Nov 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Jan 12, 2009 | Kenmore 43142 Front Load Washer
Everything works fine but my dark clothes always come out with white marks on them.
there is not a filter that you can clean easly you can take your agitator off and clean what you can get to.the lint should drain away at every drain cycle.
when you take off the agitator off you may see 2 holes about the size of a quarter they have what looks like little combs in it this may trap lint
Sep 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My washing machine smells stale! If clothes are left in overnight they go smelly too.YUK!
your drain has lint stuck in it ,when the washers done the spin cycle the lint is still there and starts to smell when its done,remove drain hose and remove lint
Jul 07, 2008 | Hotpoint Washing Machines
Kenmore washer always makes lint on clothes
yeah check my four boxes and send me an e mail at b4829@yahoo.com ref lint on clothes
May 22, 2008 | Kenmore 22422 Top Load Washer
Washer leaves too much lint on clothes
There are many things that cause lint. Some are easy to figure out, some aren't. Here are some of the most common things: 1. Separate clothes that are lint givers from lint takers (i.e., sweaters are lint givers and should not be washed with cotton which attracts lint). 2. Check clothes pockets for tissues or paper. 3. Don't overload the machine. 4. Use enough detergent to hold the lint in suspension. Read the recommended usage on the detergent bottle. 5. Use enough water to rinse the lint away. Washing large loads on a water saver mode is not a good idea. 6. Use fabric softener to reduce static attraction of lint. 7. Washing clothes on too long of a cycle, too often can cause premature wearing of the the fabrics. I hope some of this may help you. PS Adding a cup of plain white vinegar to the rinse cycle has also been known as a "cure" for controlling lint.
Apr 04, 2007 | Kenmore 22442 Top Load Washer
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
273 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
