Question about Porter Cable 2" Flooring Cleat Nailer FCN200
Nailer piston won't retract far enough
After only about 10,000 nails thru this nailer, the piston suddenly stopped retracting far enough to be able to fire a nail (it retracts to about 1/8" of overlap with the next nail). There's no jamb and the feed mechanism works fine. It gets oiled before every use, but it sounds like something in the pneumatic area is hanging up. I'd like to take the thing apart and inspect for wear and at least clean and oil it. It seems easy enough to disassemble, except that I can't figure out how to remove the rubber cap so I can get to the actuator under the exhaust cap. I don't want to force anything... what's the proper method to remove it? And any suggestions for the best oil to use during reassembly? Thanks!
  • rmolner Jun 13, 2009
    Problem solved. After taking the gun apart, it turned out that one of the two retaining clips had broken. A 3/8" long piece of the upper clip somehow broke off (probably defective hardening) and jammed itself at the top of the retract path. No damage was done other than a ding in the aluminum. We just happened to have a factory service store within 30 miles, so I went there with my broken part and they gave me a new clip and a small amount of silicon grease for reassembly (no charge... very nice of them!). There was no other wear, so I cleaned every part and reassembled the gun, which now works perfectly. A couple of notes: first, this nail gun is constructed very well and from its internal design and manufacturing quality I'd say it should last a very long time. I can see why it cost me close to $400 (purchased from Amazon last year). Second, the toughest part of taking the thing apart was figuring out how to get the rubber strike bumber off the thing. I could find no information about it and didn't want to force anything. Turns out it's glued over a tapered shaft. I used several wooden wedges on either side of the gun to slowly force if off the shaft. If I ever have to do it again, I'd make a wooden wedge tapered from 1/8" to about a 3/4" inch thick with a slot cut thru the middle to allow the shaft to pass thru and just tap it between the gun head and the bumber. Otherwise it was a piece of cake to work on.
    President:
  • 497 Answers
The rubber cap just pulls off. maybe a screw driver to pry it first but it does just pop off.
As for oil, Always use what the manufacture recommends. But in the case you can figure that out, use a low viscos oil, maybe a standard 3-1 will do in most cases.
Also WD-40 works well.
Posted on Aug 10, 2009
I have a porter cable roofing nailer model # RN175 that does not advance the nails everytime what causes this?
Some causes, in order of probability:
Roofing nailers get a lot of tar build up on them, especially around the nose safety and nail feed pawl area. Cleaning off this buildup will usually take care of most problems with roofing nailers.
On the side of the gun away from the side you load the nails on there is a small cylinder with a piston inside that attaches to the feeder pawl. If air isn't getting to the piston or the piston's o-ring or spring is damaged, it won't cycle properly to advance the nails.
If the driver doesn't retract fully, the next nail won't be able to advance properly for the next shot. This can be caused by o-rings in the head that are worn or out of their proper place.
Oct 06, 2012 | Air Tools & Compressors
Hi I am having problems with my porter cable air nailer.. 2" brad nailer.. The hammer is not retracting far enough to hit the next nail.. I have taken it all apart and cleaned it and re oiled it but...
This is usually a sign that the hammer is slightly bent or the o-ring seal is going bad. You have to replace the hammer. If replacing the hammer doesn't work, the barrel it rides in is out of round and will need replaced. These pull out hard and you need allot of grease and patience to get them back in square to keep the seals intact.
Mar 03, 2011 | Porter Cable PorterCable FNBNNS3TB Factory...
Nailer fires first nail successfully but next nail jams. It appears the part that retracts after each nail is ejected does not retract all the way so the next pack does not load properly. Have cleaned and...
first make sure you are using the right guage nails. then I would look at the condition of the driver to make sure not bent, also look for a broken nail in the magazine area which will also cause this, lastly does the piston/driver "fall" in the cylinder?? there should be some resistance against the o ring, if not then it could also cause your described problem,
Dec 21, 2010 | Stanley Bostitch SB1664FN 16 Gauge...
I have Bostitch RN45 coil nailer. It sometimes does not feed nails. When I open the magazine the driver blade has not retracted. Gun does not leak, o-rings in drive section look to be in good shape and...
Causes of piston not retracting are as follows. Cracked /worn bumper, if cracked air will leak between piston and bumper. Try test, remove nails and dry fire gun against rubber or soft wood; depress trigger push gun against wood/rubber and hold in this position. Piston should stay down and no air should leak past nose. Worn piston oring, piston should not slide down cylinder under its own weight. Loose or missing check seal, remove cylinder and look for black rubber band around series of holes. Band should be in place and fit snuggly. Good luck
Oct 20, 2010 | Stanley Bostitch Rn45b1 Industrial Coil...
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Piston blade won't retract
I've had a similar problem and found a nail had broken and lodged itself in the nail housing causing the driver to get stuck forward.
Apr 22, 2010 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
N-80 vintage 1986 the striker does not return far enough to engage the next nail. If I turn the gun upside down and tap lightly on the head it will usually allow the striker to retract.There are no air...
you have lost compression on your piston o ring, instead of air pushing the piston back for the next nail its going around the piston , and the proof is that your piston will move with a simple tap. please replace all orings, because if one is worn the others arent far behind, if you dont replace all , at least replace the piston one and all the cylinder ones,,o rings kit are available at your nearest nail store or try toolpartsdirect.com plz rate this answer,,tks
Dec 11, 2009 | Stanley Bostitch N80s Nailer -rebuild...
N100 framing nailer does not retract piston
Try oiling it. That is the most common problem. Also, make sure you are using the correct nails. If they are not genuine Bostich nails, try them.
Nov 28, 2009 | Stanley Bostitch Coil Framing Nailer
After each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
Mar 25, 2009 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Porter Cable 2" Flooring Cleat Nailer FCN200 Logo
942 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
