Home | Rockford Fosgate | Punch 401S Car Audio Amplifier | 401s Rockford Fos...
Rockford Fosgate Punch 401S Car Audio Amplifier
Problem for Rockford Fosgate Punch 401S Car Audio Amplifier
401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
By olddewsons on May 30, 2009
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck After i got my car jumped my amp has the protect lite on not power lite please help
Comments:
May 30, 2009
- thanks for reply,this model has 3 led lites top one is power, 2nd one is termal,3rd one is protect, no matter what we do,this lite stays on. this all happen after we needed a jump,the power lite will flash fiant blue at the sametime the protect lite flashes.it on for 10sec then flash,10sec flash. we disconected the speakers and the booster,still the same.we pulled all fueses as we were told too,to reset.again nothig. i hope this helps. thankyou......duane.
May 31, 2009
- am sry i will have to check. its my sons car,and he wont be home till late. thank you for reply. sry.
Sponsored Links
Clarification Request
Posted by pbabin on May 31, 2009
Are you sure that this is a Rockford 401S?
Rockford didn't use blue LEDs until later.
Posted by pbabin on May 30, 2009
I don't think that model has a protect LED. It only has a power LED. If the red LED is lit on the top of the amp, the amp is most likely working.
Have you checked the speakers?
Have you confirmed that you have a good signal at the amp?
Best Solution
posted on Jun 16, 2009
Very Helpful)
palaboy
Rank: Wiz
Rating: 82%, 1142 votes
try disconnecting the speakers, whatever connected to the amp audio input terminal, power it up, if there still no power the trouble is inside your amplifier, hope this help, thanks for using fixya!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 02, 2009
Somewhat Helpful)
Cutlass85
Rank: Master
Rating: 78%, 10 votes
try hooking the remote wire to a rem wire on the back of stereo. post and let me know results
Was this helpful?
Yes
No
Solution #3
posted on Aug 28, 2009
Not Rated)
laseramp
Rank: Wiz
Rating: 85%, 68 votes
the problem is mostly with your audio side of the amp. i have a 800 Rockford punch series amp hooked in series running at about 15 vdc at 2 ohms stable for now. but the amps left front power side transistors overloaded and smoked out, i will be replaceing my mosfets soon. Now on that side your issues apear to be related to the signal side of the amp. when you hooked the amp up tell me breifly did you hook the rca inputs to the back of the sterio and did you select the proper rca inputs for the amp? also note that amps have a potentiomater that can be tuned up or down to allow the volume or wattage to go up or down threw the system. if it's turned all the way down you'll here nothing. but often you'll get a pop sound or quickly see the speaker move a bit. this indicated the signal side of the amp has signal comming in but no output, just look for a turnable small screw inside the amp top or side. and turn up acordingly. note: to much output will damadge your system. not just the amp. ;)
Was this helpful?
Yes
No
Solution #4
posted on Aug 12, 2009
Not Rated)
shorty d
Rank: Apprentice
Rating: 0%, 0 votes
ok i just got a 401s rockford fosgate amp for my 2001 dodge and i got it grounded and power hooked up plus the remote wire hooked up but it wont respon
any suggestions?
Was this helpful?
Yes
No
Popular Solutions for Rockford Fosgate Punch 401S
Questions and Unsolved Problems for Rockford Fosgate Punch 401S
Do you recommend Rockford Fosgate Punch 401S Car Audio Amplifier?
Answer
Answer
what do I need to find out radio code for Hyundia 99 excel vin# KMHUD11NPXU438829
Answer
i got 944 volvo 1996 and the imobilizer don,t go off. thank you
Answer
I have a dls amplifier and when i connect two specific input phonos coming from the radio to the... (More)
Answer
The mirror on my rubicon jeep,2005,, has a garage door opener .built in and I need to know how to... (More)
Answer
i lost my owners manual for my memphis 16prd1000.1 and i really need to know how the wiring harness... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rockford Fosgate Punch 401S...:
Top Car Amplifier Experts
Rank: Guru Guru
Solutions: 14022
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Amplifier Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
