Question about Maytag MTB2176HRS Top Freezer Refrigerator
Need to remove drip pan
Drip pan needs cleaned on maytag mtb2178hr refrigerator because fridge is stinky and have done all other cleaning....pan seems to not be able to be removed
    President:
  • 1,136 Answers
Hi, This pan can not be removed without taking the whole frame apart. Best thing is to try and get a long brush (hardware stores sell them) and try and clean it that way.
Using very hot water might help loosen the grime in the pan.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Drip pan
The drip pan is located behind the toe panel (grille) at the bottom. The pan should be located in the left side. If you have auto defrost, the pan may or may not have water in it. It is likely to have accumulated grunge which can be removed by a good wash and rinse, being careful to avoid breaking the pan during cleaning. Reinstallation is the reverse of removal.
Sep 12, 2012 | Maytag MZD2766GES Side by Side...
Drip pan replasment on mzsd2665heq
Hello there,
To remove and replace the drip pan on your refrigerator, please follow the instruction below:
  1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
  2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
  3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
  4. Slide the drip pan forward until is free of the Maytag refrigerator.
  5. Empty the drip pan in the sink.
  6. Replace it with a new one,
  7. Then you reverse the process to reassemble it back together,
  8. Plug it back to the power outlet.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | Maytag MZD2766GES Side by Side...
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
Stinky drip pan
Try vacuuming and cleaning the coils on the bottom of the fridge. The water is supposed to evaporate by the heat/air movement and if that is being slowed by dust and junk clogging the coils...it won't evaporate the water.
Jun 11, 2011 | Frigidaire FSC23F7D Side by Side...
Stinky drip tray
soap and water to the defrost pan is the only way if odor is inside place crumpled newpapers in the section for 1 day then unused coffee 2 cups this will absorb odor inside of the unit
Aug 19, 2009 | Maytag PTB2454G Top Freezer Refrigerator
How do I clean my drain pan on my side by side refrigerator it smells
Hi. Thanks For The Question. Pull Fridge Away From THe Wall. Remove Back Panel Clean All Coils. Remove Drip Pan. Clean. Thanks The Appliance Doc
Aug 07, 2008 | Maytag MSD2656G Side by Side Refrigerator
Odor
Sorry I don't know this model, so I can only give generic advice on this one.
Most fridges have the cooling plate at the back. Try to keep food away from it, otherwise ice will form on it.
At the bottom of this area there will be a gully and drain hole through to the back. Any drips that form at the back, will drip into this gully, go through the hole, down a pipe and onto an evaperator tray sitting on top of the compressor.
What usually happens is that dust or labels get stuck to the cooling plate at the back, which drips down, blocking the pipe, which then stagnates into a grey stinky soup.....Lovely!
What you need to do is defrost the fridge, spray clean the inside with a multi-surface cleaner, and flush this tube with the cleaner water. A turkey baster syringe may be the easiest way to do this. As the evaperator tray only holds about 1/2 a cupful - don't overdo it.
While you are there, clean the door seals.& dry the interior.
This should cure the problem.
Thank you for using Fixya!
Jun 14, 2008 | Whirlpool GD2SHGX Refrigerator
Maytag MTB2176HRS Top Freezer Refrigerator Logo
439 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
