Question about Nvidia Geforce FX 5200 Graphic Card
Primary display issue
I have been trying to setup my nVidia GeForce 5200 to use the DVI port as the primary display port.  I have updated all BIOS and drivers.  The new driver recognized the port and gave me dual monitor display options.  I set selected the configuration to use my DVI port at the primary display device.  This immediate closed down my VGA port (now secondary), but did not bring up the DVI display.  I have rebooted, reinstalled the video card, etc and still don't have video to my LCD monitor.  I have tried all port combinations.
The current state is that I cannot get a display to work. Is there a hot key to show the secondary display so I can try to switch back.  Is there any work around that will allow me to see a display?
  • 4 Answers
Try going to Windows Safe Mode. You do this by pressing the F8 key repeatedly exactly after you hear your computer beep when it is rebooting. This should bring you to a screen that will have 3 Safe Modes listed, choose just plain Safe Mode by using your arrow keys to highlight Safe Mode and press enter. Once in Safe Mode, a box will come up asking you if you intended to enter Safe Mode, click Yes. You should now see your desktop, however it will look larger, and with less colors. This is normal.
If this mode did not allow you to get into windows, then reboot, press F8 like before and select Enable VGA Mode instead.
Now that you hopefully have a desktop, try this link which will take you to a video that will walk you through the process of setting up your DualView monitors. Also, note that there are some check boxes that allow you to select which monitor you want to be the primary.
I realize this video is specific Windows 2000, but the process is the same for Windows XP.
Hope this helps and Good luck!
Posted on Dec 23, 2007
SOURCE:
Setup dual-boot disks, one loads VGA instead of GeForce 6200
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Nov 18, 2007 | XFX GeForce 6200 Graphic Card
I have nvidia g force fx-5200, suddenly no display, what to do for repairing.
its better to use DVI o/p jack... you will be providen a jack its looks like fig below...
use this your graphic card will show display...
Dec 21, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the...
Hello ghinea18, sorry you can't do that because this will cause hardware conflict, that's why motherboard bios automatically disable integrated graphics if you install video card using pci express x16 slot - Nvidia GeForce 7300SE. do you know if your video card has dual vga or dual dvi connection?
You can try dual display, im not sure if this card supports dual monitors because nvidia online specs does not show full specs on 7300se series. \
Good Luck!
Nov 24, 2010 | Computers & Internet
I have a GeFORCE FX 5200 PCI card, and onboard graphics. I had to restore my system, and cannot find the user manual. If it was available online, I'd follow the steps myself, but I'll settle for a quick...
Hi.
You do not necessarily need to disable the built in graphic adapter, the computer can manage two different adapters.
The nVidia should show picture with standard VGA definition (800x600 only) if simply connected to the AGP or PCI slot even if drivers are not installed, and even if built in GPU is not disabled.
If there is no picture, check installation in slot, check that card is not disabled in BIOS, check video cable is well connected, and if nothing works, test the video adapter on different PC, the card may be faulty.
Here the manuals:
Quick Guide to NVIDIA GeForce Desktop Graphics Processors
GeForce FX 5200/5500/5600/5700/5900 Series
GeForce FX 5200/FX 5600/FX 5900 Series
nVidia GeForce FX5200 Gigabyte GV-N52128DS manual - GeForce FX5200 ...
Sep 30, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
No signal on HDTV
Your graphics card is probably too old to support HDTV signal (720p, 1080p)
Dec 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
Dvi port not workink
Change monitor input on nvidia control panel and /or change the input on the onscreen display. mine uses the same thing
Dec 27, 2007 | MSI FX5200-TD128LF GeForce FX 5200, (128...
Computers & Internet Logo
156 people viewed this question
Top Nvidia Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
