Question about Saeco VIA Veneto Espresso & Coffee Maker
The wand is coming out - Saeco VIA Veneto Espresso & Coffee Maker
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
When I go to use the wand and froth the milk the black rubber part of the wand is coming off every time I put the wand into the milk.
There should be a "c" washer which retains the wand. Sounds like it is missing. Hardware store should have something that fits. Taker the wand with you
Mar 13, 2015 | Saeco Aroma Black Espresso Machine
How to install the wand handle catch
If the wand keeps coming away from the machine then it is likely that on the back of the machine the four pegs that hold the wand in place 1 or more are broken.
If this is the case then the fault is not the wand but the spine of the machine. You would require a new or sevond hand spine and it would mean completly stripping it.
Apr 02, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
New Vacuum won't release extension wand
I had the same problem. All I needed to do was unwind the cord which was tying the wand tight to the canister. I must admit I called Shark for this solution. Very embarrassing for me but the Rep was patient and kind. Their Customer Service Department was easy to reach and very committed to solving the problem. They get an A+ and I get a big fat F!!!
Nov 14, 2013 | Shark Rotator Professional Lift-Away...
I have a Simoniz S2500 pressure washer.I cannot get water to come out of the wand. When I disconnect the wand and turn on the water without starting the engine, water will come out of the gun. I reattach...
@dstephensond
Have you tried pouring water into the wand and see if it comes out the other end.To me it sounds like the wand is blocked at the end.Or try blowing in to it and put your hand at the end to see if you feel the air coming out.If it's blocked with calcium pour in some CLR leave it over night and see if it worked.If it's a piece of dirt take and air hose and blow air from the nozzle end out towards where you attach it to the gun.
Alfman
Apr 14, 2011 | Garden
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Dyson Animal Hose collapses
The blockage is in the wand itself - take it off the back of the machine and separate it from the gray hose. Hold the wand into the air and look through it. If you don't see the light coming through the other end, there is a blockage in the wand. Remove it with a long object like a metal hanger. The DC07 wand is slightly bent at the top - you should still see some light coming through the top though. Be sure to look through the metal rod end of the wand, otherwise you probably won't see anything anyway.
Jun 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Dec 07, 2008 | Rancilio Silvia Espresso Machine
Saeco VIA Veneto Espresso & Coffee Maker Logo
15 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
