Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Sonic Pride Scooter won't move
New batteries installed. Gauge shows fully charged. Slight sound from horn. Reset pushed and fuse checked. Lever in rear does not go all the way to rear/unlock position. Not sure if it is in push or unlock mode. Scooter has hav very little use and never been outside of home.
  • 118 Answers
SOURCE: Pride Sonic Scooter
You can check the voltage going to the motors. The clicking you hear is the brake releasing. most likely, I bet water or something got on the controls and the signal is not getting to the controller. I hope its not the controller, they list for around $350.
Posted on Nov 27, 2008
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
FixinFax
  • 3085 Answers
SOURCE: instruction manual for pride mobility sonic & celebraity scooter
Go www.pridemobility.com in the products section.
Posted on Jun 18, 2009
  • 103 Answers
SOURCE: pride sonic scooter won't turn on. the battery is
How do you know that the motor is functional? Have you load tested the batteries. If the batteries are bad usually they will still take a surface charge and appear to be fully charged.
Posted on Jul 23, 2009
  • 61 Answers
SOURCE: My Pride scooter is fully charged but there isn't
Does the battery meter move and does the green LED on the console come on? If not, then this would probably be the circuit breaker has popped or possibly a fuse blown somewhere. There may be a fuse on each of the battery harness leads, so they could be worth a check. May also be a bad connection somewhere or a broken wire. Also worth checking the key switch incase this is not working. If the green LED on the console IS on, is it flashing and if so, how many times. This is a built in diagnostic system and will tell you what is wrong with the scooter if you have the owners manual to refer to. Hope this helps...
Posted on Mar 19, 2010
Testimonial: "Thanks for your help. One of the connection from the battery was burnt"
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
Feb 18, 2017 | Pride Health & Beauty
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
Won't move with charged batterys
Hi, any bleeping, flashing lights , double check the freewheel lever,
1. Any clicking from the rear .
Please keep me updated.
Regards
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
1997 PRIDE VICTORY GIVEN TO ME, BUT NEEDED FRESH BATTERIES PURCHASED NEW BATTERIES INSTALLED THE KEY, LITES & HORN WORK BUT UNIT WILL NOT MOVE FORWARD AND/OR BACK
check the freewheel lever on th rear of the chair near the right rear wheel if you can push the scooter easily then you are in freewheel locate the lever and move it to the drive mode and try to drive the scooter again if it still won't move then you have other problems that can only be checked by a service tech Hope this helps
Feb 26, 2011 | Pride Mobility Products Pride Mobility...
Batteries fully charged on pride legend fuses, isolater checked. checked all wiring appears good connection but system dead, please advise joe
Hi ,you need to check whether there are any fuses under the seat,
Does the horn work ? , do the power tiller ? the display showing how much the battery is charged
Regards
GeWiz
Aug 02, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Battery fully charged, buzzing sound when i try to ride scooter, but scooter will not move
check the FREEWHEEL LEVER at the rear of buggy to make sure it in the drive position, if you can push the buggy it not in drive mode.
Jun 11, 2009 | Pride Sonic 3 Wheel Portable Scooter
Battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Nov 21, 2008 | Sonic 3 Wheel Scooter
New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Oct 29, 2008 | Pride Sonic 3 Wheel Portable Scooter
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
207 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
