Question about X2Gen MG19VT 19" LCD Monitor
Screen goes black but power light stays on
I have an X2gen 19" wide lcd monitor. I think the model number is MW19R if that means anything. The problem is that whenever I turn my monitor on, it only stays on for a few minutes. The time seems to vary slightly. The screen will just go completely black as if it was powered off. However, the blue power light is still on. Therefore, I can simply press the power button to turn it off and then press it again to turn the monitor back on. The monitor then proceeds to work for several minutes and again and then the problem repeats.
  • electroneer8 Jan 19, 2010
    andalampuan:
    The J is a capacitor code that means 5% tolerance.
  • 33 Answers
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
Posted on Aug 09, 2009
  • 748 Answers
You have several capacitors on the power supply board which have changed their value. Using an ESR meter they'll be easy to locate. Sometime you can even spot them because they have bulged out their tops. If you don't have the capability to test and replace these then send it to a pro. I repair these all the time for a modest charge. You should be able to find someone locally.
Posted on May 30, 2009
My x2gen mw19r wide lcd monitor just went black while i was using it but it is still on wont display at all.. know wut it can be? and a website i can order parts from
Posted on Aug 16, 2010
Hi fixit24132
are you sure that 27J3KV is a 27 pF 3000 volts? or is it a 27 Joule energy capacitor operating at around 3000 Volts w/c must have capacitance of 6 microfarad?
this is quite confusing. i hope u can help
Regards
Posted on Dec 26, 2009
After hooking up my Dell to the monitor it displayed a message ! " Out of range ," the monitor then went black . How do I fix it ?
Your screen resolution or refresh rate is set out of limits for the monitor. Check your monitor documentation to determine the correct resolution and refresh rates for the monitor. Then reboot the PC, go into SAFE mode, then re-adjust the display resolution there. Once you reboot after that, the monitor should be fine.
Nov 06, 2013 | X2Gen Mw19r 19" LCD Monitor
I have x2Gen 19" LCD Monitor. I hooked up the
More likely to be the fuse for the backlight inverter circuits rated at 3.5 or 4Amps. It is PICO fuse.
The transistors that drive the inverter transformers may have been damaged, should check them out before installin a new fuse. In the mean time you can use 1 to 2 Ohms 1/2 Metal Oxide (MOX) resistor in place of the fuse, if the resistor overheatand open up then you have shorts circuits.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 19, 2010 | X2Gen MG19MY 19" LCD Monitor
My 19 inch x2gen mw19r monitor just went black its still on but wont display a picture so now im using my old tube monitor want to fix the x2gen
titter101, You left out telling us the "DATE of MANUFACTURE" for your unit. You will need to use CRT unit while researching info on x2gen mw19r unit. If unit out of warranty, then you or qualified technician will need to do the investigation and repair of unit. Read the fixya profiles of "budmrtn" , "buddymc" , "12fixlouie" to see if a DIY repair will work for you. 12fixlouie
Aug 16, 2010 | Computers & Internet
Screen goes dark after 1minute, power lite stays on
Possibly the lcd ccfl inverter. Ebay sells universal ones for 9 to 25 dollars each. Monitor repair knowledge needed to replace this part.
It could also be your external power supply if it is not OEM. Or if it failing under a load. If the picture is good when it is on, I always start looking at the power supply and the ccfl inverter/transformer. Please understand I am not an expert on LCD's I just seem to get lots of failing ones. ---Hope this helps.
Jul 25, 2010 | X2Gen MG19MY 19" LCD Monitor
Mn x2gen monitor will not power up. The power supply's led is illuminated. The light on the power button is very dim. Model #MW19R
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 10, 2010 | X2Gen MG19MY 19" LCD Monitor
Black out
even i had this same problem.....its two 220uF25V capacitors and one 47uF35V capacitor located on the backlight inverter chip covered by a plastic shield. It works just fine now. Be sure you get the polarity right when soldering in the new capacitors. It is marked by a shaded in half of the outline on the board and a line on the new capacitor. This was on x2gen 19inch wide screen though so check the specs of the capacitors on yours first. They all together cost around $5 at Radioshack.
hope i was helpful thank you
hav a nice day
May 19, 2009 | X2Gen MG19MY 19" LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen MW19R picture only stays on for one to fifteen seconds...
Dear Chris,
Visually check the component :
Try checking on the power board , may be ESR of capacitor is faulty and power resistor shorted and burnt.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19VT 19" LCD Monitor Logo
1,447 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
