Question about Car Audio & Video
All the wires were cut about 5 to 6 inches from the radio plus it was hooked up to an amp and a boom box
How do I install this radio into my daughter's 1994 jeep grand cherokee? It was my sons radio installed in a late 1980's S 10 pickup there are no instructions to be found. Can you help? the radio is a Panasonic CQ C8400U MOSFET 60W X 4 MXE
  • 74 Answers
Hi there you will find a full manual on your radio here
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/CQ-C8400U%20-%20CQ-C8400-_E
regards JR
Posted on May 30, 2009
How do I wire a tuner plus 3 mic to a vintage realistic trc 458 cb radio ?
Hi Carl, I found 2 different hook-ups so I will list them both. You can check them out according to the wire colors you have in the mic cord. First one and this may be for a turner mobile mic. ;
Turner
1- Shield & Red
2- N/C
3- Blue
4- White
5- Black
Yellow NC
This one is out of the Turner book but they did not list your radio exactly. This is the most popular hook-up for Realistic's.
Code E;
1-S
2- N/C
3- Bk
4- Wh
5- Red
Hope this helps, Mike
http://www.cbtricks.com/mic_manuals/turner/turner_mic_wiring_book.pdf
Oct 29, 2015 | Radio Communications
I have 2 12" kicker solar baric squares L7 hooked up to a kicker cx 1200.1 amp as soon as I turn bass knob up it cuts out and amp goes into protective mode plus I have a 3 microfarad copasitor hooked up...
Sounds like your wiring is giving you the wrong impedance,Check crutch field advisors website for sub box construction and detailed wiring instructions.
Aug 22, 2014 | Car Audio & Video
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Instructions for the 500 watt amp
1/remove positive cable from battery.2/install rca jacks to rear of your radio/unit.3/find a suitable safe out of veiw area to mount amp with adequete ventilation [because it will get hot] .4/run and tuck your rca's agian outta site,never in a door jamb.5/also most install kits have a auto on/off wire that runs with the rca wires,that gets tied on to your power antennea wire on the stereos wire harness6/once you have rca,automatic on/off hooked,or near your amp ready to plug in.,you can then , cut as short as possible ,the ground wire[that should be black in color]the shorter the ground wire ,the less feed back you will get! under 14 inches is best .mount the ground very secure under a front seat, loosen a mounting bolt to the seat then wrench tight[making sure it is metal to metal,no paint can be in between contacts then run the power wire [red to red] straight to your battery positive cable [very securely] you should find a access point to push the wire thru the firewall someplace do not hook up the battery though finish runnin the power wire to amps destination after the amp is secure ,add power wire plug ins to amp then runn your speaker wires to box re-attach battery terminals [will be a small spark ] dont panic . upon turning on listen to your favorite song loud,so you can adjust the amplifier to yer liking
Mar 20, 2011 | Visonik Vpb210pk Complete Dual "10" 1,000...
My wiring plug to the back of the radio was cut on my 1990 4runne
fun fun fun.
1990 Toyota 4Runner Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Negative Wire (-): Purple
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Jul 31, 2010 | 1990 Toyota 4Runner
Amp is connected to the + wire, shared with the car radio itself. When i turn on the car radio the woofer only ''booms'' around every half a second and gets louder, even when no music is being played. Amp...
the problem lies in your wiring . you need a amplifier wiring kit u can get best buy that can handle 650 watts and go direct to battery under the hood. just the battery positive running to the + on the amp.make sure the remote wire or the r+ on the amp is not hooked up to power.what radio do u have?
Mar 06, 2010 | Car Audio & Video
I need to add outdoor speakers,and the headphone
I would run the headphone jack to an amp then hook up you outdoor speakers to the amp.
Oct 07, 2009 | Sirius SUBX1 Universal Plug and Play Boom...
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
5 inch Tv
Yes.  You need an adapter that has a coax end on it with a mini jack on the other end.  Radio Shack carries them.
I just got done putting one in my car myself.
Sep 10, 2008 | Televison & Video
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
