Question about Coleman Heating & Cooling
The compressor cuts on when the weather is warm
The ducane unit is a three ton unit operating off of R22 also its a single phase. The contacts work the fan works and I have 24 volts on the t-stat. Every now and then the compressor cuts on maybe once a week when. I need a list of things to check for
    Problem Solver:
  • 6 Answers
Do you have a humidistat or a setting on you thermostat to regulate humidity? that would do it regardless of the temperature.
other then that, the only thing that can close that contactor to run the compressor is the t-stat or loose wire/short of the yellow control wire with the red 24V.
Benge
Posted on May 31, 2009
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
Hi I purchase a 3 ton -3 phase condensing unit. Dayton model 1nxd4 for a friend house,after the instalation was finish the unit will not turn on. after installing the unit i found out that the unit was...
Three Phrase is usually only avail at a commercial
business
You would need a complete additional service to the house just for the AC
They would have to install a new transformer on the pole
I would suggest replacing the motor if that is the only issue,
to single phase 240 volt
May 23, 2011 | Heating & Cooling
Need to how many tons it is .mn 13aja42a01
Your unit is a 3.5 ton, 13 seer, single phase. Have a good one!
Aug 26, 2010 | Weather King Heating & Cooling
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
York 3phase compressor tripping on low currant microprocessor.
If the unit is single phasing this is not good for the compressor. Does the system have a phase monitor? If not I would suggest you put one in to save thousands of dollars on the replacement of the compressor. How is the oil level? I ask because this are not to run themselves out of oil.
Jan 12, 2010 | Mastercool 67471 Evaporative Cooler Air...
I have a 220 440 electric motor on my 4 post 3 ton car lift which ran on 3 phase, how can i run this motor from a single phase supply, regards dave
You need to either change the motor to a single phase or check into a single to three phase converter...I would do which ever is cheaper myself. You could go single phase, but the cost of operation would be higher depending on the duty cycle.
This link may help: http://www.phaseconverter.com/starting-load.html
HTH
Mike..
Nov 20, 2009 | Plumbing
Voltage 1phase or 3 phase 240 volts BTUs M# 585epo36o75
Looking at the model number, it appears to be a 3 ton. (36,000 btu) Most all residential units are single phase and most all commercial are 3 phase. One way to tell, look to see if the compressor has a capacitor. 3 phase never use capacitors on the compressors as they are not needed. Some residential units have a "Dual" capacitor. That is, it has 3 terminals, 1 common, 1 for condenser fan motor, and 1 for the compressor. Also, this info should be printed on the unit's lable.
Good Luck and hope this helps.
May 09, 2009 | Amana Comfort Zone 12M32PBEH Air...
Heat load calculation
Here are a few ways to calculate your BTU's.
Get ready to use that algebra you thought you'd never use.
1 Ton = 12000 BTU's
400cubic feet per minute (CFM) = 1 Ton on standard ac units (300 is an absolute minnimum)
BTU's air heat = difference in temp. ( ∆T ) x 1.08 x CFM
∆T = BTU's / (1.08 x CFM)
i.e. 65F entering your unit and 93F air leaving on a 12000BTU unit.
∆T = 28
CFM = 400
28 x 1.08 x 400 = 12096BTU's
Another way...
Electric heat calculations.
BTU's = KW (killowatts) x 3413
Watts = Volts x Amps (single Phase) Most Homes))
Watts = Volts x Amps x Phase (this is for three phase units.)three wires and a ground))
120 volts 30 amps single phase (common)
120 x 30.0 x 1 = 3600 or 3.6KW 3.6 x 3413 = 12286BTU's
Aug 09, 2008 | LG BG8000ER Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
