Home | Coleman | (5040B750) Patio Heater | Charmglow gas patio hea...
Coleman Patio Heater
Problem for Coleman (5040B750) Patio Heater
Charmglow gas patio heater
By doramia on May 30, 2009
our patio heater is a little over a year old. It will not turn on. when you push the ignition switch you get a loud ticking sound, nothing happens. the gas cannister is full and is operational, as it works on the grill. thanks for any help. GET SPECIFIC PLEASE!!!!! My pilot lights - and then goes out when I let go. How do I "clean it out"? What "little hole" am I suppossed to poke? Do I need to unscrew/take the whole heater apart?
Solution #1
posted on Jun 01, 2009
Not Rated)
co7196
Rank: Wiz  Air Conditioners  Expert
Rating: 85%, 1022 votes
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
Was this helpful?
Yes
No
Popular Solutions for Coleman Patio Heater
Questions and Unsolved Problems for Coleman Patio Heater
Do you recommend Coleman (5040B750) Patio Heater?
Answer
Answer
What does OH mean on a hot tub control panel
Answer
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and... (More)
Answer
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but... (More)
Answer
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve... (More)
Answer
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coleman Patio Heater:
Top Heater Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
