Question about Canon EOS-5D Digital Camera
SHUTTER JAMMED SHUT ON CANON EOS 5D
Hi there!
The shutter on my Canon EOS 5D digital camera is jammed shut. Camera displays: 'Error 99'
The mirror moves when you take a shot, but the shutter is stuck closed.
The Canon on-line manual is no help at all. Describes 3 other errors, and then 'Error 99' as "...different from the above errors..."
Great!
Anyway, any clues? I have a big photoshoot coming in 4 days and need to sort this asap!
Thanks,
Grant Wakefield
firethistime@hotmail.com
  • 667 Answers
It would seem this problem has frustrated other users, read this thread on photo.net
Posted on Jan 27, 2008
How to fix canon 5D mark 2 error #30?
On the 5D error code 30 appears to be shutter related and general advice is to get a professional repair or send it back to Canon.
Aug 04, 2014 | Canon EOS 5D Mark II Digital Camera with...
When I try to take a picture I get an error 99 message. Shooting is not possible turn off power switch or remove battery
Hiyou have very common problem of canon dslr product. usually problem come from defective shutter unit. However, there is cause from lens also. Would you remove lens and push shutter button? if no error 99, then the problem come from lens---usually power diaphragm control fpc defective.If shows error 99, then you have body problem. At this point, still you have to check more. please set camera M mode and bulb shutter speed, you have to look front of camera if mirror goes up and show to you picture sensor. would you tell me more later. Thanks and best regard!
May 27, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
My 5d mark 11 camera screen appears error20 and it wont remove
Hi
Error code 20 on a Canon EOS 5D Mark II indicates there is a hardware problem with either the mirror or the shutter. The only solution is to have it repaired - or if the camera is reasonably new take it back to your supplier and get your money back.
Hope this helps
David
Jan 13, 2011 | Canon EOS 5D Mark II Digital Camera
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My camera wont turn on. The battery is freshly charged, it is installed properly and the battery compartment door is shut correctly. At one point the flash would come up, but no display on the lcd and the...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99 comes up every now and then I can continue shoting though if Ieither take the battery out and put back in or open and shut the memory card slot, I've tried just getting a new memory card but that...
I hope that helps.
Nov 06, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
View finder displays "busy" and the shutter is half open
I can help you fix the BUSY Error or Error 99 of your Canon EOS Digital Rebel XS.
Installation of this Canon EOS Digital Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
May 28, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99 message keeps popping up
Hi
I just read that the error 99 problem is a shutter failure and the shutter will have to be fixed. The cost is about $180.
see http://www.mcvr.com/canon_digital_rebel.htm?gclid=CJqG4cvc05oCFRMhnAodCHUA3Q#shutter
ERR99 (error 99) is an indication that there is a communication problem in the camera. It is most often an indication that the shutter needs to be replaced, but it can be the result of other problems. All digital cameras occasionally need to have the shutters replaced. In the days of film cameras, it was rare to wear out a shutter because the cost of film and developing limited the number of times the shutter was cycled. With all those ones and zeros being considered "free" in digital cameras, it is not uncommon to take several hundred or more photos in a day. Even with a live-expectancy of 50.000 to 100,000 cycles, the shutters in digital cameras do reach the end of their life and need to be replaced.
Shutter replacement (usually associated with error code "99"):
  • Replacing the shutter on the Digital Rebel series requires more disassembly than most other repairs.
  • The estimate for shutter replacement is $180 on all EOS Digital Rebel models (depending upon the overall condition of the camera).
  • ERR99 error codes are related to shutter or mirror operation and are usually associated with a defective shutter. Cameras that have had heavy use may have shutters that have reached life expectancy and need to be replaced.
May 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon utilty program freezes then wont close when remote shooting
Check to make sure you have the latest updated software and firmware. You can check at
http://www.usa.canon.com/cusa/support
Mar 12, 2009 | Canon EOS-5D Digital Camera
No shutter actuation, no menu display, no autofocus.
check the battery and flash card doors. are they propely shut?
Jan 25, 2009 | Canon EOS-5D Digital Camera
Canon EOS-5D Digital Camera Logo
657 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
