Question about Uniden BC248CLT Base Scanner
Need help on programing my 20 channel 10 band scanning radio
Have no mannul for my 20 channel 10 band scanning radio bc148xlt. need some help with programing my channels
  • 1,305 Answers
Here's a link to get the Uniden owner's manual... Look for the grey box in the upper right corner.. this will get you up and running ... You may also want to do a google.com search for " radio frequencies" and " your state here".. that will help you find the local radio freq's.
Here' s the link to the manual
Posted on May 31, 2009
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
I have been all through the Uniden Bearcat Scanners and I cannot find what I'm looking for. I am looking for a manual or instruction for a Uniden Bearcat Scanner that was given to me. The MODEL # is:...
Your can download and print the manual for your scanner, at no cost, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC148XLT%20%28Manual%29.pdf
Bill B.
Listening in since the 60's
Feb 21, 2011 | Uniden Bearcat Pro PC78LTW 40-Channels...
Uniden bearcat scanner BC148XLT-1 Can't program it because it is locked out
Try manually unlocking each channel by selecting it and then pressing the LOCKOUT key. That will normally clear the channel for programming. If that doesn't fix the problem, power the scanner OFF, then press and hold the MANUAL, 2, and 9 keys while powering the unit ON. That should restore the scanner to its original factory settings.
Need the manual for your scanner? You can download and print it, at no cost, here:
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Aug 11, 2010 | Radio Communications
I need help with programming my BC148XLT scanner please
Programming the BC148XLT is pretty straight forward:
1. Power the scanner ON.
2. Press MANUAL to stop scanning.
3. Enter the number of the channel to be programmed.
4. Press MANUAL again.
5. Enter the frequency, including decimal point (ex: 250.145).
6. Press E to enter the data into memory.
7. Repeat steps 2 through 6 to program remaining channels.
More detailed information can be found in the scanner's operating manual, which you can download/print here:
Bill B
Jul 03, 2010 | Radio Communications
I have a uniden bearcat scanner model#bc148xlt and it seems to not want to take the local frequencys and it comes up error when you hit the enter or e button
You didn't mention what frequencies you're trying to program. BC148XLT coverage ends at 512 MHz, so you will get the error message if you try to program anything above that. Also, you must be sure to include the decimal point when programming a frequency into the scanner. I hope this helps.
Need the manual for your scanner? You can download/print it here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 20, 2010 | Radio Communications
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Frequency Coverage:
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Need a free printable user manual for Bearcat scnner BC142XL
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Sep 06, 2009 | Uniden BC-95 XLT Scanner
Programming the BC244CLT
Hi, If I'm reading correctly, that scanner is listed as a 30 channel scanner only. You can pick freq's from 10 different bands. Here's just some of the features listed, hope this answered your question.
Mechanic
FEATURES:
  • Clock/Alarm - Large backlit LCD displays time and features "any button" snooze.
  • 30 Channels - You can program each of these memory channels to store one frequency.
  • 10 Bands - Including all public service bands, 4 "HAM" bands, federal and military land mobile bands.
  • Weather Scan - Automatically scans all national weather service frequencies.
Jan 17, 2008 | Uniden BC244CLT Base Scanner
Uniden BC248CLT Base Scanner Logo
287 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
