Question about Ruud UAMB Air Conditioner
Rusty vent in boat house door
I have a hole (12" x 12") in a door in my garage that opens to my boat house which is located under my townhouse. The hole is covered by a vent (grill) which is made of metal and I need to replace it with a vent made of plastic or PVC because it constantly rusts out. I have tried Lowe's and Home Depot and they do not carry a vent the size I need which is currently 14" X 15". Can you help?
    President:
  • 2,976 Answers
You can put on a brass vent cover, it will outlast you and the cost is less than replacing the tin one every 2 or 3 years.
Posted on May 31, 2009
I can't get the battery compartment open on my KEYPAD. Recently bought the house and former owner gave me codes but I am getting no response so need to ck battery. LiftMaster 973LM is model # on the...
There is a small hole on the bottom of the unit. Take the pointed end of a pen and press it in the small hole.....that will help pop the cover open to replace the battery.
Aug 02, 2013 | Sears Craftsman LiftMaster Chamberlain...
I reset my liftmaster/chaimberlain keypad (976LM) and now can't access garage. Is there a default code? No other access into garage (new owner to this house).
Make sure the battery in the keypad is good. You cannot reset the keypad without access to the opener. You will have to find a way into the garage.
A door technician uses a special tool to pull the emergency release after drilling a small hole in the door. The door can then be lifted without damaging anything. A keyed manual release assembly is then installed in the hole to be used if there are problems in the future like a power outage or malfunction like you have now.
Aug 11, 2012 | Sears Craftsman LiftMaster Chamberlain...
Batteries need changing in the garage door remote control. It requires the code to be reset but the previous owners of the house left no information. It is a Wayne Dalton, Magic Touch, Model Number...
Using a step stool reah up and remove the plastic light cover from the garage door opener and the the code setting instructions are written on its panel. Or seach on LiftMaster.com for help.
Jul 26, 2011 | liftmaster Remote Light Control Garage...
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
I must have hit the lock out key by mistake i have no service door or lock release help
I think what you are saying is you have no way into the garage other than the large door and your open er is not working. If you cannot force the door up enough to crawl under it your best bet is to call a door company. They will drill a hole in the door and use a special tool to pull on the release rope. They can then install a mechanical release in that hole for future use.
Jan 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener (GDO) model 139.53985D, only a couple of years old. 315MHz remote controls. Opener has stopped responding to the remote controls,unless a remote is held wihin 12 inches of the...
There is no way to change that radio frequency it is set by the government. Sears service technicians have an instrument to help them locate the interference that causes this type problem.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2hp garage door opener does not go down to floor
I'm no expert, but on a previous door opener I had (don't know the brand), the side adjusting screw basically adjusted a limit switch, which was located inside the plastic housing (where the motor is). I was able to remove the housing, figure out which limit switch was actually being contacted "too soon" on the way down and adjusted it while watching it.
Just a suggestion, you might take a look.
just keep your hands out of the way of the chain and sprocket if you do take the housing off. .
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener chain out of sync with door
There are two white screws on the sides that adjust the limits. Adjust the "down" screw less. You should have to turn the screw 4 full turns for eight inches. After you make this adjustment, test it without the door being hooked up to prevent damage to the door or opener if it tries to close too far.
Feb 27, 2009 | liftmaster Chamberlain Garage Door Opener...
Ruud UAMB Air Conditioner Logo
60 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
