Question about Casio G-510 G-Shock Cockpit Series G510-6
I went to put the battery in and a spring fell out. Where does it go?
I went to put a battery in my watch and a little spring came out. Where does it go?
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Can't remember where the little spring go in the g-shock 300
The used of the spring of your watch is for the speaker connection of the back cover of your watch. Your watch is still working even without the spring but no sound of alarm or whatever sound feature.Just go to watch service center im sure they have spear for the spring if not they can make spring from the watch spring bars.
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Posted on Jan 26, 2009
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
gemineye61
  • 831 Answers
SOURCE: I have a Timex datalink
Its alot more complicated then you think. If you want to do it right, I would suggest taking to local watchmaker, or call Timex (see link) to send in for repair. Sorry but thats the best advice.
http://www.timex.com/info/Repairs
Posted on Aug 12, 2010
Spring fell out while putting smaller battery in. Can't locate where spring goes?
the spring goes in a small hole at the back of the watch and locates on the backplate to activate the alarm
Sep 23, 2015 | Watches
Tip
LOST SOUND AFTER BATTERY REPLACEMENT.
If you experience no sound (alarm) from your watch after battery replacement, that means the coil spring fell out of watch while the battery has been replaced. Coil spring is transmitting vibrations from watch movement to the sound membrane at the back cover of watch, and if it is lost, there is no physical body to transmit signal, thus no sound. Coil spring itself is quite tiny and can be easily lost without even noticing it, mostly because it is not soldered to the watch movement or sound membrane and as soon as the opened watch is turned over, the coil spring fells out. If you are not able to find the coil spring in/around the place where the battery change took place, there is no other solution but to visit your nearest watch repair shop and ask to fit new one. In case if you are lucky enough to find the coil spring, fit it back in to appropriate hole in watch movement inserting out-bent end into movement. In most watches coil spring holes are marked: C.SPRING/COIL SPRING/ C.S or similar. Hope it helps.
on Mar 31, 2010 | Watches
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Took apart a polar s150 watch to change the battery. I went too far and 2 little springs fell out and a small black rubber donut. I don't know how/where to put these back. The two springs appear to...
Hello Clintsanders,
I am sorry to inform you but there is no way that you can repair the unit yourself, you will need to return the unit to Polar to be repaired. Here is a LINK to Polar and all of there service centers and the numbers and procedure that you need to follow in order to return your unit for repair.
Sorry but this is not a DIY item.
Thank you for choosing FixYa.com
Justinbur167
May 16, 2011 | Polar S150 Heart Rate Monitor Wrist Watch
Looking fo ra parts break down for the DW-9052 Casio. Was replacing the battery and the spring and a little metal tab fell out. trying to find out where they go.
if its a tiny little spring then those springs you will need to put them in a little hole on top of the movement so they press up against the back of the case when y ou put it on . I am not sure what metal tab you are referring to , but I am pretty sure it is the tab that goes on top of the battery and holds it down.
Oct 14, 2010 | Casio DW9052-1V Wrist Watch
I have a Casio AQ-47 watch. I removed the battery
This little spring is called coil spring and must be inserted in to the hole in movement. Usually there should be writing on movement with an arrow pointing to that hole. If you can not find the writing, then try to put coil spring in different holes one after another, till you hear the watch beeping again.
Rate me, plz.
Jan 11, 2010 | Casio Classic AQ47-1E Wrist Watch
Regards;
VOTIT
Jan 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio Databank 150
If your databank is like mine (DB-35H), there is a TINY spring in a really unusual spot that you probably didn't notice that fell out. Laying the watch face down and with the back off, there is a little tiny hole in the back towards one of the corners. (sorry, already put my watch back together and didn't notice which corner.) There is a tiny (1/16" x 1/4") spring that sits upright in that hole. It must make a contact with the metal cover. I replaced my battery and when I did, a spring fell out. I looked all over the internet, then wrote Casio, who said they didn't have access to the information about where the spring went. (Doh!) I got a used DB-35H from my brother and was going to swap the innards when I noticed the spring on his. Put my spring back and it beeps! If you've lost the spring, don't know if you can fake it with tinfoil or not, but it really is a TINY spring. Good luck.
Mar 26, 2008 | Casio DBC1501 Wrist Watch
Watches Logo
188 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
