Question about Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour
Elkay water cooler does not turn on
I have bought a elkay water cooler used and worked very well, now a week later when I returned to my office I noticed the water was not cold and no matter what I do I can't get anything to power up.
  • auscam May 30, 2009
    this by the way is a water cooler for the 5 gal water bottles and not the fountain pictured above.
  • 20 Answers
You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
Posted on Jul 17, 2009
My Elkay water fountain is clogged up, water does not drain properly, how do I unclog
To unclog the elkay water fountain just look out for push button catridge and and turning it to adjust how far it is pushed or you can even try with chemical drain cleaners like draino or liquid plumber or CLR(Calcium,Lime and Rust Remover) & if still the problem hire plumbing repair services.
All Plumbing Repairs
Apr 29, 2015 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Elkay vrc hd8 drinking fountain is leaking how do i fix it
Replace the gaskets on th ep-trap and thre tray to drain gasket.
Aug 18, 2014 | Elkay EZS8-L Single-Level Wall Mount Water...
Water from Elkay wall mount water cooler is coming out cloudy. I know it has air in system and i let water run for over 5 mins but water remains cloudy. Looing for solution
  • Check the water shut off valve is not open all of the way if not open shut off valve all of the way.
  • Check to see if the regulator / control valve is restricted with debris or not working properly. If so clean debris or replace the control valve.
  • Check the water inlet screen is for debris, clean or replace screen
  • If there is an external water filter, check to make sure it is not clogged.Check the income water line, if flexible, to make sure it is not kinked, is it is rework it to remove the kink.
    Dec 06, 2012 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    I have power and water to the fountain, but fail to get the water to pump to the fountain head
    The water pressure get the water to the spout it is not pumped there. You have a valve in the off position some where. http://www.elkayusa.com/cps/rde/xbcr/elkay/12-23D_EZ_EZS_EZSD_EZD.pdf this link shows an electric solenoid valve and also a manual valve.
    Feb 18, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
    HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
    I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
    Sep 16, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
    On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
    Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Water pressure is low on the elkay fountain
    if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
    Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
    Need temp control for water cooler has BOTH HOT/COLD
    Company called Ranco makes replacement contols. Contact your local Appliance Parts Dealer.
    Apr 22, 2009 | Refrigerators
    Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour Logo
    556 people viewed this question
    Top Elkay Plumbing Experts
    jdthefixer
    rdjagger
    Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
