Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Compaq 2500 Here's the problem. When he got it, windows was corrupted and wouldn't boot to windows without a ton of error messages. He told me to wipe the drive clean and re-install XP. He handed me a fresh, recently purchased version of Win XP home and told me to do away with HP's proprietary version of XP. I figured, easy enough. I've done this kind of thing many times with many older computers.
  • Chris May
    Chris May May 11, 2010
    Could you elaborate. Does windows not install? or are you asking how to install windows onto his computer?
    Scholar:
  • 113 Answers
The disk itself may be corrupt , go to microsoft and download xp home or pro , whatever your using and burn to a disk .If you don't have access to another computer , go to a repair shop and you can usually buy a burn't copy of xp for 5 to 10 dollars . RE-install as usual. please note !!! you must know what service pack is needed for the install . SP1 - SP2 ....OR to be on the safe side just get XP SP1. good luck!
Posted on May 30, 2009
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
My n610c started then error message came up saying windows had a problem and needed to close then nothing lap top powers up but will not restart windows i havent got a backup disc
More than likely you have a bad boot sector on your hard drive, there is little you can do without the operating system to re-install. if the computer has a floppy drive or you have a USB floppy drive you can use a Windows 98se disc and use fdisk to wipe the partition. There are several other disk utility programs that will accomplish this as well
Nov 28, 2010 | Compaq Evo N610C Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Boot manager is missing and wont load windows 7 on compaq presario c700, no matter what i do it keeps returning to the boot manager missing press ctl alt dlt.screen how do i fix it
If your using a DVD to install the operating system, it could be either dirty (just needs a wipe) or the files on the disk are corrupt.
If you are getting this error while Windows 7 is starting up perhaps you can try doing a "repair". Boot off the DVD do a repair (not from the recovery console) and see if this helps.
Hope this helps.
Nov 08, 2009 | Compaq Presario 700 470024-192 Notebook
Problem with compaq presario 2500
hi
go to the Bios setup and set the first booting device as CD drive and it will check the CD first
cheers
pls rate if it was any help
Jul 05, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
Error Code
All you can do is Reinstall windows. You should get the Windows Vista Installation CD with your laptop and all you have to do is put it in and restart your computer and when the message that says "Press any key to boot from CD" press a key.
If it doesn't show up, you may have to press a key like DEL or F12 to get the boot sequencer. When you first turn on the computer you should see the Compaq logo. At the bottom of the screen you should see some buttons to press to do things like BIOS and Boot Sequence. You want Boot Sequence. Once in boot sequence, select the CD-DVD and press any key when it says to.
Once in follow instructions or oyu can reply and i will tell you how to install.
Oct 06, 2008 | Compaq Computers & Internet
Windows installation
sys file from the cd is corrupted...try wd any other disc
Aug 02, 2008 | Compaq Presario Notebook
Having problems with my compaq Persario 2500
this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
129 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
