Question about Dell A920 InkJet Printer
Dell A920 cartridge stall error.
When I went in to change the ink cartridge, the cartridges flew to one side or the other but not where I could change out the ink cartridge. It slams the ink cartridge into the side jarring the printer. It's worked fine all day up to this point when I needed to replace the black ink cartridge. I've already tried unplugging everything and then trying it again. I've troubleshooted and it just said contact manufacturer. I couldn't find the help I needed on the Dell site. Cartridge stall
Hi, I HAD the same problem, but not anymore!! I just opened the top to expose the "inside of the printeri" and checked the long clear band at the rear behind the print head. Make sure that the clear ribbon is NOT TWISTED. There is a small metal bar with a small extended part on the far left interior of the printer. Just make sure that the slot on the clear band is fitted on that extended part. This will put the print head back "on track" This worked for me!!
Posted on Mar 15, 2011
I have a dell all in one printer 944. When I turn it on it keeps sending the message, "change ink cartridge" I have changed the cartridge twice and message remains the same. Is it broken?
Are you using Dell Series 5 ink cartridges?
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message, please read bleow.
Black cartridge = black side(left side) Color cartridge = Color side(right side)
Photo Cartridge = Black side(left side) Color cartridge = Color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Rick
Jun 27, 2011 | Office Equipment & Supplies
I keep getting a cartridge error message. I have replace the ink cartridges but still have the error.
Are you using Dell Series 11 ink cartridges?
Open the printer with the power on and remove the Dell Series 11 black ink cartridge and make sure the tape is off the cartridge, then reseat the cartridge back in. Now do the same for the Dell Series 11 color cartridge. Now when you close the printer, it should print an alignment page. Any error messages?
Black = Black side(left side) Color = Color side(right side)
Photo = Black side(left side) Color = Color side(right side)
Dell Series 11 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 11 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It possible to get a Dell Series 11 Cartridge with a bad sensor. Take back to place of purchase for a replacement.
Rick
Jun 15, 2011 | Dell 948 All-In-One InkJet Printer
I have a Dell Photo926 printer. I just changed the color ink cartridge and it is giving me an alignment error stating remove tape from cartridge. There is not any tape on the cartridge. I have ran the...
Are you using Dell Series 9 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
You are using Dell Series 9 ink cartridges, correct?
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Apr 26, 2011 | Dell 926 All-In-One InkJet Printer
New ink won't print i think it is full of dust
Hi
Some times it needs a good clean up but this is up to you if you want to do this I put down here. But after you don this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 13, 2010 | Dell A920 InkJet Printer
My Dell A920 printer will not print the color blue. I've replaced the ink, 2 times. Changed the quality of print to "Best" and still get only the reds & yellows... Any ideas?
hi there !
-try the old cartridge if it will print the correct colour; the problem is the cartridge; otherwise it is the printer.
cheers !
Oct 24, 2009 | Dell A920 InkJet Printer
I am trying to copy and print with dell A920, but it says: cartridge stall the current print job has been canceled 1. turn the printer off 2. open the cover 3. make sure - the cartridge are snaped into...
Hi and welcome to FixYa,
Initially, check/clean the encoder strip. This would be the long narrow plastic strip with barcode like markings. Ensure that it is clean, no smudges, ink marks or any paper debris that may obstruct a light sensor passing through it other than the barcode like markings.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 11, 2009 | Dell A920 InkJet Printer
Dell A920 Printing Problem
You should check:
1. Did you insert correct the cartridge in the holder?
2. Check if the contacts are clean in the cartridge holder, maybe something is ther and the needle-type contacts from the printer does not push right on the cartridge contacts.
Feb 14, 2008 | Dell A920 InkJet Printer
Flashing Green Light/ Computer can't communicate with printer......
Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
Hope this helps.
Dec 14, 2006 | Dell A920 InkJet Printer
No printing
DEAR SIR I REPLACED THE DELL INK JET CARTRDGE.TAKING THE OLD OUT.AND SNAPPING THE NEW BACK IN.THE BLACK AND COLORED NAME PLATE FACING ME.AND WHEN I HIT PRINT.A SIGN COMES UP.SAYING CARTRDGE STALL.WHAT DO I DO TO GET IT TO WORK. AL
May 28, 2006 | Dell A920 InkJet Printer
Dell A920 InkJet Printer Logo
532 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
