Question about Foxconn 661FXME Motherboard
No 1394 port located on MoBo as manual indicates. Is it mislabeled?
Foxconn 661FX Plus MoBo is supposed to have 2 IEEE 1394 ports as noted on the manual and schematic, but my board seems to be incomplete. There is an Audio adapter where the 1394 plug-in should be. And I can only find 1 1394 labeled on the board, not 2. Am I mistaken?
    Brigadier General:
  • 10,406 Answers
Return the motherboard to the place where you bought it, and have them explain the differences that you have observed.
Posted on May 31, 2009
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
How can I get Windows 7 Movie Maker to recognise input from my Sony DCR TRV18E Handycam?
On page 230 of the user manual, it describes how to transfer movies from the camera to a computer using an i.Link (IEEE 1394) cable. You will need the 4 pin i.Link cable and an IEEE 1394 connector on your computer in order to do this. You cannot use the USB cable to transfer the video from this camcorder -- you can only transfer still images using the USB cable.
You will have to buy this i.Link cable and (if you don't have a IEEE 1394 port on your computer) a IEEE 1394 adapter card for you desktop computer. If your laptop computer doesn't have a IEEE 1394 adapter, then you're pretty much out of luck.
Once you have the i.Link and 1394 issues resolved, then Movie Maker should then recognize the camera.
Dec 27, 2010 | Sony Handycam DCR-TRV18E Mini DV Digital...
WE HAVE NOT CONNECT TO PC MYSamsung VP-D371i MiniDV, Digital Camcorder
From the user manual, I've discovered that you have to use a IEEE 1394 cable (see the jacks display on page 11) to be able to download the movies from your camera. The camera does not come with a IEEE 1394 cable -- it only comes with a USB cable, so you will have to buy the cable.
Unfortunately, most PCs do not come with a IEEE 1394 connector and you have to buy an adapter card for a desktop computer. If you laptop does not have a IEEE 1394 port, then you are out of luck.
Once you have the cable and the port on the computer squared-away, check page 87 of the user manual for directions on how to retrieve the the video from the camera to the computer.
Dec 24, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
Is there any firewire port IEEE 1394 (FireWire/i.LINK)in sony hc dcr 52e
Yes, DCR-HC52E has IEEE 1394 port, it would be labled as iLink or DV
Check left to power jack.
Thanks.
Nov 25, 2009 | Sony DCR-HC52 Mini DV Camcorder
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Oct 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
FoxConn 661MO3-G-6EL is suuposed to have 2 1394 Firewire ports installed, 1 in the rear panel and 1 accessible on the board from a front bus connector, but mine seems to be msssing these, whcih does not...
Are there any wires running from the FireWire port on the front of your computer's case to any connector on your motherboard?
May 30, 2009 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
SONY HANDYCAM DCR-TRV280
To download video you need Firewire port, also known as an IEEE 1394 port.
Windows XP or Vista can save your video files.
PCMCIA 2-Port IEEE 1394 FireWire Laptop Cardbus PC Card
Jun 26, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Capture video not responding - driver issue
Are you using the USB cable that came with the camcorder? If so, then don't use it, because it doesn't work for loading from mini DV tapes to other devices. Instead, buy a IEEE 1394 "FireWire" cable (whether 4/6/ pin, whatever you need)in order to pass the videos from the camara to the computer. note: DO NOT buy a cable that has a USB on one side and a IEEE 1394 on the other side, thus it doesn't work. You must buy a cable that has both IEEE 1394 ports on both sides.
Jul 04, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Foxconn 661FXME Motherboard Logo
133 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
