Question about GE Washing Machines
Won't spin GE Model #WJRE5500G0WW won't spin goes thur all cycles but will not spin MOD#WJRE5500G0WW. My machine won't spin. It drains fine and agitates but won't spin. I've also checked the lid closure is good. Am I looking at replacing a motor?
  • suzihernande Jun 01, 2009
    Took hose off and ran through sink....no clog, so reattached. Took entire machine apart and put back together, now machine will not agitate nor spin?
  • suzihernande Jun 04, 2009
    The machine is plugged in and the front cover is off. There is no flashing light on the motor. This leads me to believe the motor is gone.
  • 1,543 Answers
Take the front panel off by using a putty knife to push in on the two clips at the top edge of the front panel. Now, pull the thin tube off from the left front side of the outer tub. Cut off about 1.5 inches of it and replace. Test. This tube tends to plug up right there. It's really best to just clean it out, as if the problem reoccurs, you will soon run out of tubing. I usually see this problem with machines which rarely, if ever, see regular liquid bleach used. To prevent this from happening again, fill machine to the lowest water level, using the hot water, and several cups of bleach (no clothes) and run a cycle through a couple times a year. Make sure to rinse machine before using with clothes again.
Posted on May 30, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Jun 01, 2009
    When your washer is plugged in, with the front panel off, look at the top right side of the motor (just under the top cover ). You should see a green light which flashes. Tell me how many flashes, and if they are fast or slow.
    Carl Schulzetenberg Jun 04, 2009
    When you look at the motor, the C2 connector (the one on the left side) should have 120 volt across terminal 3 to terminal 5 at all times when the washer is plugged in. Can you check that?
    Note: the blinking green light I'm looking for is located a bit up and to the right side of the C2 connector on the motor, just under the cover, near the front of the motor.
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Clicking Sound between agitation and drain cycle
Is it a front loading or top loading washing machine?
Oct 08, 2007 | Washing Machines
Washing Machines Logo
262 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
