Coding for timer in c#
I want coding for timer in c#
  • 296 Answers
Timer not working it blows a breaker when turned on
Describe timer in detail so it can be identified:
http://waterheatertimer.org/How-to-troubleshoot-timers.html
I don't know a timer with error codes... and if breaker blows then timer is wired wrong, or load is too heavy for load rating of timer, or using wrong voltage.
Gene
h
Dec 04, 2013 | Hardware & Accessories
My et103c will not manually or electronically turn off my pool pump.
Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
Unknown if this is new installation, or old installation that stopped working.
Check battery. The timer requires a battery. Located below the buttons.
ET103C digital electronic timer is discontinued but some folks still sell on ebay... selling possibly used timer. Timer has 1 year limited warranty from date of manufacture.
Timer has error code messages... if you receive no error code, then battery could be problem.
Line noise can cause timer not to function, such as fluorescent lights on same circuit etc.
ET103C clock mechanism is 120Volt 60 Hz. If pump and circuit are 208-240Volt, or 277V etc then this timer is not best choice unless neutral wire is available..
Add a comment and describe situation in more detail.
May 02, 2013 | Intermatic & Indoor/Outdoor Rain Tight...
Wiring color code for timer mcbr1010w
Numbers are 2143 Colors are 2-Pink 1-Yellow 4-Blue 3-White This is if you are looking at the bottom of the timer facing the numbers. The Pin that is separated from the other three is number 3-White Wire.
Jun 19, 2012 | Hardware & Accessories
How do i change my timer
Please make sure that the wiring is not tampered and taken out. Purchase the same type of timer and connect the wires after you have a sketch diagram with the wire codes so that no terminal wiring mistake is done while changing the timer.
Use the colour codes or use wire codes on the wire so that a wrong wiring is not possible.
Mar 11, 2011 | Dryers
I bought a used Xbox360 and the family timer is set on it. I want to reset this but unable to. There is a description on here that is a gentleman explaining how to solve the issue but its not working for...
When the Xbox 360 Family Settings are first setup, you are required to give it a four-button pass code in order to add or change settings.
There are two ways to edit or remove the Family Timer.
If you do have the pass code:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Enter your pass code.
  4. Select Family Timer.
  5. Select Disable.
  6. Select Done.
  7. Select Yes, save changes.
Now your timer should be disabled!
If you do not have the pass code:
  • Try contacting the previous owner.
  • Call Xbox Customer Support at 1-800-469-9269
Note: Some information taken from Xbox Support.
Family Timer
Pass Codes
Oct 06, 2010 | Microsoft Xbox 360 Console
Stopped working. no0 p code
1) Can you identify your timer and then re-post your question?
Here is a link to Intermatic >> on left side of page are types of timers. Press + to expand each selection. There are a lot of timers. It sounds like you have electronic timer, and not a mechanical timer.
2) Guessing at solution without knowing exact timer?!?
Could that code mean 'no power'
Have you checked circuit breaker, click it all the way one direction, and then back the other way
Does manual override work? Does manual override turn the load on-and-off?
Have you checked battery?
EH40, EH10, ST01C, EJ500, EI600 each have a battery, but usually the error code is BATT
Sep 30, 2010 | Intermatic Hardware & Accessories
I want to format my nokia 1100. i juz wan 2 reset th timer
for reset timer u dont have to format mobile
just go to call register in menu u see clear timer option select it mobile will ask for lock code
if u have update any phone lock insert it or just insert 12345 (default code) all timer will reset
Feb 21, 2009 | Nokia 1100
Code for blinking label in visual basic
follow this
http://www.pcmag.com/article2/0,2817,1951108,00.asp
Is the line executed? Did you start the Timer (calling start method or
setting enabled=true)? Do you execute other code while you expect the Timer
to tick? If you do, the Timer won't tick before the code has finished it's job. To solve it, execute the other code in another thread. This prevents the main thread that also keeps the Timer ticking, from being blocked by the other code.
Jan 29, 2009 | Microsoft Visual Basic 6.0 for PC
Amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Nov 16, 2008 | Amana Ovens
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
