Question about Samsung BlackJack II Smartphone
My password will not work and there is a timer underneath my phone that is at 2 hours and I cant even try to type in a password until the two hours is up and it keeps saying password incorrect when I
My phone will not accept my password and there is a timer on it. Anyone know of a default password to reset it and how to do it please? i cant remember my device phone code does any one no a master code??
  • 421 Answers
Give me your imei no
Posted on May 30, 2009
Cant remember my samsung s5620 Monte phone unlock code
Hi, You can try using PUK code from your sim card to unlock samsung monte S5620 password. Just type any password until your screen asking PUK code, then enter you puk code to your phone. This method should be unlock samsung phone from old password. If that method not working reflash your phone in nearest local mobile phone repair shop.
Sep 02, 2011 | Samsung S5620 Cell Phone
I have the blackberry 8520 and last night it lock and i got a message saying memory cleaning. Now for the last 12 hour all i have is a white screen with a timer, the phone is completely...
Try entering any password in your blackberry until you reach 10 times password failure, it should be make your blackberry curve 8520 unlocked also erased all your previous data. After your blackberry unlocked, setup new password for your phone. If this solution not working the only option is reflash your blackberry phone. Good luck!
Mar 09, 2011 | RIM BlackBerry Curve 8520 Smartphone
Have a timer that I can't get programmed. It is Brinks 42-1005, the serial # may be 1009C-A but we are not sure as there is no label for that number. The instructions were thrown out and there doesn't...
Move the dial clockwise until the arrow (marked TIME OF DAY) is lined up with your present time. Numbers on dark gray background are night time hours. Depress outer "teeth" that also correspond with hours of the day & evening (ea. tooth = 1/2 hour) for the chunk of time(s) you want the appliance ON. Plug timer into outlet and appliance into timer. There is a manual TURN ON slide switch on the left of the timer for your convenience as necessary.
Jan 25, 2011 | Hardware & Accessories
How do I program the timer to turn on and off at specified times?
You need to program the timer so it turns on-off at specified times.
But first we need to identify your timer for sure.
Have a look at link below.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
If your timer does not show, then add a comment with description of timer.
I have extensive files on timers.
Intermatic DT300, GE 15091, and Woods 59203 are the same timer.
Here are instructions for Woods 59203:
Plug timer in until battery is recharged.
If display will not show, then timer battery needs to be plugged into outlet for 1 hour until internal battery is recharged, or timer is bad, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Once display shows, then unplug timer for programming.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
If instructions don't fit your timer, then add a comment with model number or full description and I'll post those instructions.
Also you can take advantage of Fixya phone service where expert speaks with you over the phone for a price.
Dec 21, 2010 | RTO Intermatic DT300CL 8.3 Amp Seven Day...
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
I caNT SEEM TO PROGRAM OR CHANGE THE TIME . HOW DO I DO IT
Page showing Woods timers and models:
Add a comment with specific model number and I will help.
Instructions below are for Woods 59203 24-hour digital timer:
If display will not show, then timer battery is dead and needs to be recharged, or timer may be broken.
Set current time:
Program timer:
Nov 27, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How to clear call timers
The clearing call timers should be in the following scren.
1)Go to menu
2)Select call register
3)Select call duration
And clear it all the info will be lost you might be asked for a password. If you have never set a password the default one is 12345
May 28, 2010 | Nokia 3120 Cellular Phone
Keypad on the slider doesnot work
u cant rectify the problem by just formatting..try changing the keypad
Apr 07, 2010 | Samsung J700 Cellular Phone
Blackberry cell phone locked up
I HAVE A PROBLEM SOME1 WAS TRYIN 2 UNLOCK MY PHONE AND ON MY LAST ATTEMPT I MESSED UP NOW I CANT UNLOCK IT AND ITS CANCELED BECUZ I WENT 2 ANOTHER PLAN BUT A
LL MY CONTACTS ARE IN IT HOW DO U UNLOCK IT
Jun 04, 2008 | RIM BlackBerry 8700c Cellular Phone
Samsung BlackJack II Smartphone Logo
109 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
