Question about Acer X193W LCD Monitor
Monitor wont stay on- blue light is on. but screen keeps going blank.
My monitor light stays on but my view only stays on for a few seconds then screen goes black... like its sleeping or something. blue light stays on. if i press the button on / off the screen will pop on for a few seconds then go off again HELP!! same problem ... changing cables won't help ...
  • geroi May 30, 2009
    I tried monitor with 1 laptop and 1 pc, both with the same result ... I presume that monitor is faulty :(
    Novelist:
  • 152 Answers
Have you tried the monitor on another computer? If so, and it works, the issue is with your graphics settings on your computer. LCD and plasma based monitors often come with a protection circuit that disables the monitor if the synch or refresh rate are beyond it's capabilities. this is to protect your monitor from damage.
Do not exceed your monitor's max resolution.
Resolution is determined the following way:
Width x Height @ Refresh Rate
For your model:
  • Max Resolution 1440 x 900 @ 75Hz
More detailed information about your monitor can be found HERE. If your monitor is still under warranty, and you find it to be faulty, you may be able to send it to the manufacturer for repairs.
Posted on May 30, 2009
  • Chris May
    Chris May May 30, 2009
    Yea, sounds like it to me, you either have a faulty cable, or the monitor's inverter board is starting to go, You may need to replace the monitor, or have a skilled technician test the monitor, and replace the inverter board.
    If the monitor is still under warranty, you may be able to ship it to acer for repair.
HP Compaq Presario turns on monitor stays blank
Yes it could especially when it does not work on another monitor.
Try another video card.
Sep 22, 2012 | HP Compaq Presario PC Desktop
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
My monitor will not stay on and goes black after a few seconds when I reboot it. I'll turn the monitor on and it stays on only for a few seconds but I can see all of my programs for those few seconds.
maryfoldesi1, Your monitor power supply is going into shutdown mode becauce it has detected a fault within the unit. A technician will need to evaluate it. Before doing anything visit YOUTUBE to view vid clips of "LCD monitor disassembly" and "LCD monitor repair" Also read more of my responses to other owners that have BLACK SCREEN problems and find out all your options you have open to you. You did not tell us if you can still see the Win-desktop AFTER it goes BLACK. Is it also BLANK or can you still see a faint image on lcd panel if holding a bright flashlight 1 inch from screen? lmistyrel on aim.com 12fixlouie on fixya
Dec 14, 2009 | BenQ FP731 17" LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Problem with monitor
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Sep 14, 2008 | ViewSonic VX2235wm LCD Monitor
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Monitor displays breifly then goes to blank screen
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Acer X193W LCD Monitor Logo
675 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
