Question about Sharp PC UM10M Notebook
Need to Upgrade Hard Drive & Memory for Sharp PC-UM10M
Can you help me?
Thanks, Nathan 305.684.9426
  • Anonymous Mar 28, 2008
    Manual for the sharp UM10M.
  • 457 Answers
CPU Ultra Low Voltage Mobile Intel® Pentium® III processor 600 MHz-M Memory 128 MB SDRAM, not expandable (model PC-UM10) 256 MB SDRAM (model PC-UM10M) Video ATI Rage Mobility M (including 4 MB video RAM) Display 12.1" XGA AGLR TFT LCD (1024 x 768) Hard Drive 20 GB Pointing Device Glide pad (touch-sensitive control pad with 2 buttons) PCMCIA 2.1 Card Slots Type II x 1, CardBus port supported Audio System Monaural microphone and monaural speaker, sound system compliant with AC 97 I/O Ports USB, LAN, modem, headphone, microphone, DC in, expansion port for port bar Modem 56Kbps (V.90) LAN 100Base-TX/10Base-T AC Adapter 100-240V, 50-60 Hz Battery Rechargeable lithium ion battery Battery Life Standard battery - approx. 3 hours. Optional extended life battery (CE-BL18) - approx. 9 hours. Battery life is based on ZD Battery Mark 4.01. Battery life may vary based on actual usage. Dimensions 11.1" x 9.1" x 0.65" (min)/0.77" (max), 282mm x 232mm x 16.6mm (min)/19.6mm (max) Weight 2.89 lbs., 1.31 Kg Operating System Microsoft® Windows® 2000 Operating Environment Temperature: 50°F to 95°F (10°C to 35°C) Humidity: 20% to 80% (non-condensation) Power Consumption Max. 40W Available Options Extended Life Battery CE-BL18 Optional longer life battery 6X CD-ROM Drive CE-CD05 External USB CD-ROM Floppy Drive CE-FD04 External USB Floppy Drive Port Bar CE-PB01 Provides additional I/O ports
Design and specifications are subject to change without prior notice. Some options may not be available in some regions.
Posted on Oct 22, 2007
  • Peter Hirawani
    Peter Hirawani Oct 22, 2007
    Underneath is the memory cage secured by two screws remove
    them and look to see if the slot is available to put in an extra 128MB SDRAM chip its capabilities is 256MB as stated above.
    For the hard drive it should come out from the side just buy a new hard drive that one you have now is standard of 20G but still capable of runnin XP if you haven't already installed.
How to upgrade the memory
to upgrade the hard drive space capacity of your pc you need to buy another hard disk drive and add it to your computer....
Jan 21, 2011 | Toshiba Computers & Internet
I want to upgrade my Toshiba Qosmio G25-AV513 to windows 7, but I understand that some of the programs will not function properly due to the old hard drive. Is this true or is the company I called for...
Uhm. I am typing this from a Qosmio G25-AV513... Using Windows 7.. With the original Hard drive.. Someone is lying to you. Lemme guess.. Best Buy?? Anyway.. It wasn't a totally straightforward upgrade.. You will need a little computer knowledge (finding drivers, ETC.) And since this computer came with a RAID setup, you will need to download the windows 7 raid drivers, and put them on a thumb drive BEOFRE you start installing, because when you get to the install screen it won't find a hard drive, you have to put the thumb drive in and click "Load Drivers", then load the RAID driver and it will work.. Drivers are kind of a pain to find since Toshiba didn't update their website with Vista or 7 drivers.. Thanks Toshiba. If you need help, e-mail me. Good luck!
Dec 02, 2010 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
T2642 Emachine upgrade,can you recamend parts that are compatable 1GM memory. Hard drive 160 MG Viteo memory over 128 GB Thanks
Use this site to help you upgrade you T2642 e-Machine. The link shows what can be upgraded. Includes max memory the system can run;
Hope you find this helpfull.
Oct 21, 2009 | E-Machines T2642 PC Desktop
How could i upgrade me sony vaio pcg-9401
Hello applebyte,
Some of the most common Laptop upgrades consist of replacing the Hard Drive and Memory.
How to Replace hard drive
How to Replace laptop Memory
Memory for sale for your laptop
Hard Drive for sale for your laptop
Please rate my solution, thanks
Hope this helps you.
May 06, 2009 | Computers & Internet
I was given an IBM laptop t41 without a hard drive.
it will support any standard ide hard drive
Mar 18, 2009 | Computers & Internet
First, you will not be able to upgrade the video card on your laptop, since video cards for laptops are specifically designed to fit onto the motherboard and the design of the laptops body.
Secondly, sound cards as well are also deisgined that way, some sound cards on laptops are built in to the mother board and higher end sound card for laptops are specifically designed to fit onto the motherboard and the laptop's body.
Hard Drives on the other hand can be upgraded to a higher capacity but you can't add an additional Hard Drive. I have checked the specs of your laptop has 80GB IDE. You can upgrade to 120GB IDE or higher if you like. Just make sure that you purchase a 2.5" HDD (5400RPM/7200RPM speeds).
Here are examples of Hard drivers that you need for upgrade. I checked for available laptop hard drive. You can check other online stores or other computer shops near you if you as well.
links (Hard Drive) :
**Since you have installed Windows Vista, I suggest that you upgrade the RAM (Memory) on the laptop for smooth performance for Windows Vista. The maximum memory on your laptop is 2GB DDR SDRAM. Buyin RAM for laptops are a little but tricky so you can just go to the link below for specific memory upgrade for your laptop (I suggest that you purchase 2 pcs of 1GB since your system can accomodate up to 2GB).
Link for RAM (Memory) :
**If you decied to upgrade the Hard Drive, you can still use you old Hard Drive as an USB external Hard drive for storage purposes. You will just have to purchase a 2.5" External Hard Drive Enclosure. Click on the link below for the example of the product :
**If you can't click on the links, just copy the link and paste it to your's browser's address bar.
Oct 28, 2008 | Sony VAIO PCG-GRT360ZG Notebook
Need Software
Browse to this page to find your drivers/software,en
Please remember to rate all users who assist you for free :)
Oct 01, 2008 | Sharp PC UM10M Notebook
Ram upgrade
Above is a site showing some of the type of memory that you need. The memory type is 333 Mhz PC 2700 SoDIMM memory. Installation would cost $39 at Geek Squad.
Apr 14, 2008 | Toshiba Satellite A60 Notebook
Sharp PC UM10M Notebook Logo
266 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
