Question about Hayward 116k BTU HeatPro Digital Heat Pump HP21003T
Hayward pool heater won't turn on - it's getting no electricity even though we've flipped the breaker does it have an on/off or reset switch somewhere?
OUr Hayward heat pump for out inground pool has worked great for 3 years. This summer it started right up and was running just fine but now all of a sudden it won't turn on. We've flipped the circuit breaker but it doesn't help. Does the heat pump have a switch on it?
  • thepool
    thepool May 11, 2010
    Are you saying there is no power at all (no display) or there is power but nothing happens.
SOURCE: pool pump is very loud
loud pumps are most times caused by bad bearings and need to be replaced or better yet replace the whole pump new bearing cost about $100 to replace but not always easy to find someone to do hope this helps
Posted on May 13, 2009
  • 93 Answers
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
Posted on Jun 07, 2009
john224
  • 1378 Answers
SOURCE: 2 yr old inground pool Hayward pump louder than
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
Posted on Jul 10, 2009
thepool
  • 78 Answers
SOURCE: pool heat pump won't keep running
It is likely that you have a low refrigerant condition and require an HVAC person to service the unit. It's not unusual to need "freon" every so often. Call the repair man...
Posted on Apr 22, 2010
thepool
  • 78 Answers
SOURCE: Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
Hayward pool filter
Copy following link to access Hayward pool filter manuals: Each manual has a troubleshoot section.... and troubleshoot is about the same for different models of sand filter.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Your filter has Intermatic timer, and you tried the override lever with no luck... Check if circuit breaker is supplying power. Flip breaker fully off, and then fully back on.
Also I see that Intermatic timer has plastic cover over the terminals ... be sure wiring terminals are always covered by clear insulator for safety.
Add a comment for followup.
Jun 08, 2013 | Pool & Spa
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
Just had my Hayward Tristar 2-spd pump/motor replaced a month ago. I've been running it on high speed for about 3 weeks because my control pad went out and I couldn't get it to run on low speed. ...
running the pump on high speed will not have caused the problem, they are meant to run 3,450 rpm's continually. It's more than likely a supply power problem like you mentioned. Check GFI's, and breakers to see if anything has tripped.
Jul 26, 2011 | Pool & Spa
My Hayward H400FDN heater will not switch out of "STANDBY" mode when I press the mode button. Any Ideas on how to fix?
Try resetting it by turning off the breaker that supplies power to the heater. This should be located in the power box at the pool equipment. It is probably a 15 amp breaker.
Apr 18, 2011 | Hayward 400fdn Low Nox Nat Gas Swimming...
No power to heater minimax 400 pentair
turn all breaker off that are related to the pool equipment even the one at the main panel. if not check for power 220 v at the timer if power check the wires if not power the breaker may need to be replace
Sep 07, 2009 | Pentair 400k Minimax Ch Ng Mv Heater
My Hayward electric spa heater 11KW is coming on for thirty minutes, then throws the breaker. If I switch back on it will throw it again in another 30 mins or so. It appears to be heating then throws the...
Chances are that your element is drawing too much current. Check the manufacturer's website to make sure that you have the correct size breaker installed. Low water flow could also affect this, so make sure all of your baskets and filters are clean and clear.
Apr 05, 2009 | Hayward Comfort Zone Electric Spa Heater...
Hayward 116k BTU HeatPro Digital Heat Pump HP21003T Logo
158 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
