Question about Panasonic Televison & Video
Suddenly, my flatscreen tv won't turn on
All of a sudden my flat screen tv won't turn on. Remote won't work, and when I press the power button on the tv, it goes on for a few seconds...then turns off; at which time the power light blinks red.
5 Suggested Answers
  • 18 Answers
SOURCE: Display Issue; Sound, but NO Picture!
if you have cable tv try unplugging and plugging in that cable if that doesnt work you might have a bad cable. check for damage along the cord or bends in the metal ends sometimes that can also be the problem
Posted on Jan 09, 2009
  • 10 Answers
SOURCE: t.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Posted on Sep 01, 2009
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
This is a 32" flat screen TV that doesn't work. This has been going on for a while. Changed batteries in remote, nothing, put in different wall socket,
Bringing a flat-screen TV back from the dead - CNET
www.cnet.com > Tech Culture
CNETJan 19, 2011 - There are few technology tragedies as sad as a dead big-screen TV. ...good reason to upgrade to a new flat-screen doesn't come along every day, and I ...and eventually got the set working by replacing first, a blown fuse and ...
Flatscreen TVs - ConsumerAffairs.com
www.consumeraffairs.com/flatscreen-tvs
A TV repairman says today's flat-screen TVs are poorly designed ... "The TV wasworking fine up until Saturday, when it suddenly developed vertical .... is you can have it fixed for free under the warranty (if it doesn't run out - buy extended).
Top 5 Best Cheap Flat Screen TVs ' Heavy.com
heavy.com/tech/2014/10/top-best-cheap-flat-screen-tv-4k-deals-hdtv/
Oct 27, 2014 - Read on to see which cheap flat screen TV sets made our list. ... or secondary TV, but it also works great as a monitor or as a screen for console gaming..... an elderly family member who doesn't want or need those features
Dec 19, 2015 | Televison & Video
No sound on an element flat screen TV
Hi Kristen
try opening menu from the remote, click on sound and follow instructions on the screen for how to put the sound back on.
I hope you do not have the same problem, I once discovered on mine.
I had accidentally pressed the mute button on the remote and no sound.
After having restarted the tv , I sat with remote in my hand and suddenly the sound came on, I i had been pressing buttons just fidgeting.
good luck
kolbrun
Mar 25, 2014 | Element Electronics Televison & Video
The Vizio TV won't turn on all of a sudden
Are you trying with the remote and the power button on the tv? The batteries might be dead in your remote if you haven't tried the power button on the TV.
Feb 15, 2013 | Televison & Video
Have a Phillips flatscreen tv. I can't turn it on with the remote but can turn it on by pushing power button onthe side of tv. Batteries are new.
Hello, you could still have a worn out power key. Turn on the power manually(power key on the TV) then select channels/adjust volume/press the number keys.If all these work on your TV, then you know another remote is needed.
Nov 19, 2010 | Philips Televison & Video
I have a new Emerson LC320EMX 32" TV. The suddenly stopped working right. It will not turn off. There is no picture, only colored screens. When you change the channel it just shows a different color...
Your TV is still in the factory test mode. To remove from the tech service mode try this.To exit the service mode, grab the original remote. Press the cursor left followed by the cursor right button. Now press the off button on the remote or on the TV itself. Hope this helps. Thanks for asking and show a few hands of support!
Nov 11, 2010 | Emerson LC320EM8 32 in. LCD TV
Can I turn on the samsung flatscreen without a remote? The remote got water in it and will not work. Does the tv have a power button located on the tv?
Yes, channel buttons, sound buttons and power button is located at the side of the screen. Look for it. For most TV's its located behind and for some at the side and for some in the front bottom.
Nov 24, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
Help!!!!! I'm housesitting and cannot get the Fujitsu flatscreen to turn on. I've changed the remote batteries, but the red standby button the the left bottom of the TV screen keeps blinking. Can you help...
1. Try using the on/off switch that is on the TV itself and use the other buttons on the TV for sound and channel etc.
2. You might need to try a replacement remote.
3. On some remotes you need to press the "TV" button and, then, the power switch on the remote.
Oct 30, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
Having a problem...
Have you try pressing the SAT button?
Feb 10, 2008 | DISH Network IR Remote Control
Televison & Video Logo
2,160 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
