Question about HP Photosmart C3180 All-In-One InkJet Printer
TRACTION PROBLEM My printer will start to print but won't pick up the paper the rollers just keep rolling until the printer declares there is a problem. Sometimes it picks up the paper and it moves a few inches until a paper jam is declared by the printer. I've cleaned the rollers,restarted the printer,put fresh paper in,and gone to troubleshoot. Help! Please!
The cam that keep the pressure between the roller pick up and the lower feed is the solution
Posted on Oct 22, 2007
The paper will not roll through to print.....it keeps catching right as it is starting to pull through. Nothing appears to be stuck...
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. Sometime one side grips well and tries to pick the paper while the other doesn't resulting in a jammed. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Nov 13, 2010 | Office Equipment & Supplies
Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Apr 27, 2010 | Samsung ML 2010 Laser Printer
Paper feed problem The rubber drives do not pick up the paper to start printing. I think the paper tray doesn't move high enough to make the paper to contact the rubber rollers any ideas???????? for a fix
You can try to clean the rollers with alcohol, usually it's just the paper dust and ink that makes them lose traction. With the back door open you can clean the roller with alcohol on a Q-tip.
Jan 10, 2010 | HP DeskJet 895cse InkJet Printer
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Dec 10, 2009 | Dell 1100 Laser Printer
The printer won't print, it's trying to pick up the paper inside
Pull out the paper tray, at the front of the tray, there's a translucent roller in the middle. Remove the roller and clean out any waste paper dust inside & wipe clean the roller before putting it back.
Dec 10, 2009 | Brother HL-2040 Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Canon BJC-70, will not load paper, either by pressing (FF)
Clean the rollers; remove the top, wet a Q-tip with alcohol press down on the paper tray and you can roll the rollers by hand, clean them real good and the two little pads below them, the rollers get covered with paper dust and loose traction, really ! put it back together your done.
Mar 22, 2009 | Canon BJC 80 InkJet Printer
Paper not loading and getting jammed
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 06, 2009 | Dell 5100cn Laser Printer
Paper jam
take out all the paper from the loading tray, and press down on the inside of the tray 4 or 5 times, and put a sheet back in. There seems to be a physical irregularity with all 2300DL printers that causes this problem
Sep 19, 2008 | Konica Minolta magicolor 2300DL Laser...
Paper jam
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Oct 28, 2007 | Canon PIXMA MP510 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
242 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
