Question about Toshiba 42H81 42" Rear Projection Television
Need to tear down and discard Toshiba Projection TV
Need to tear down to discard our Toshiba Projection TV.
I have a Toshiba model 44NHM84 DLP projection TV that will either attempt to power on but then shuts down or when it has powered on there is good sound but no picture.
You will probably find, cahnging the lamp and resetting the timer will fix this problem.
Contact Toshiba for more information if you need to.
Toshiba.com
Oct 24, 2010 | Toshiba 44NHM84 TV
I turn my tv on and the red light next to the power button just blinks. i can fix it just need an idea of whats wrong
most probably a faulty power supply within the tv. Considering the age of the tv this is most likely to be the problem. To prevent this kind of wear and tear in the future use a decent surge protector and it will prolong the life of your components.
Oct 07, 2010 | Toshiba TP43H95 43" Rear Projection...
I have a toshiba 65H82 tv i need to move to my new house. can i lay it down or does it have to be upright?
Move it upright best for the tv.These tvs have chemicals in it three CRT tubes colors guns.
Sep 08, 2010 | Toshiba 65H82 65" Rear Projection...
Wavy line or scrambled picture when l turn the tv on it takes 30mins for the picture to come in clear
If you have a normal picture with lines through it, or if the picture jumps, tears or rolls, you have a Hyper Board that is failing. The last I checked, the Hyper Board is not available from Toshiba and has not been available for a number of years.
I hope this helps,
Skyassoc
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba tp5581a 55 in. rear projection tv.....problem
the yokes need adjusting (upside down writting) and the CRTs need alignment
Sep 11, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba Tv Problem
What is meant by "tears"?
If you can find a reputable tech he should be able to reflow solder a couple areas on the set and make your troubles go away.
Feb 28, 2008 | Televison & Video
Model 55H70 Toshia
Remember the old VCRs, which would tear up your tape if you took it into any kind of environment that could create dew inside?
This could be happening here too. Let it warm up for a day and try again.
Mr Bob
Feb 03, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 42wh36p
Please define line tearing or line hold drift==Do you mean horiz. or vertically?? Is the problem the same on all sources?? Any change hot to cold?? more diagnostic observation needed.
Aug 05, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
120 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
